587,345 active members*
5,442 visitors online*
Results 1 to 6 of 6
    May 2010
    290
    G0602 Measurement
    I have not gotten my lathe, yet......but I'm amassing components and making things for the day it shows up.
    I'm wondering if anyone can give me a pretty accurate height dimension from the cross slide to spindle center ( Not from the compound, since it won't be there after conversion). I'm modifying some plans for a turret tool changer, and need to know where the tool center should be so I can make the base to the proper dimension.
    Its a rainy Sunday, so I'm hoping to pass some time drawing.... :-)
    Dec 2009
    1416
    I was just futzing around on it tonight and was trying to get my 1/2" tool back on center. I was getting 3.070" on the digital height guage after I shimmed the tool to leave no nub in the center when facing. Used that as the center height for my cutoff tool and got good results.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    May 2010
    290
    Great......that's just what I needed.
    Jan 2010
    2141
    Which turret plans are you modifying?
    You are planning to document your build here with lots of photos, right?
    May 2010
    290
    I think I'm gonna try the ISS International. It's pretty much the same one Steelpolish made in the other G0602 thread. I was considering the "revolver".....but this one seems so much simpler, and would require much less air pressure since the piston is so big (4"). I still have some time to think about it.
    I'm gonna try to make it from mostly aluminum.
    I notice his is 3.000" to the center line of the turret. Maybe the machines vary. I'm gonna have to wait til I get mine in the shop, I guess.
    2 more weeks. It's not backordered, I just have to save a few more bucks.
    Jan 2010
    2141
    OK, I guess it's this one:
    http://www.issintl-inc.com/latheturret/
    I'm not sure that my machining skills would be up to the task just yet (but I don't even have a suitable lathe yet, so I have plenty of time to develop them)...
  1. Laser Measurement Systems
    By cncrookie_85 in forum Want To Buy...Need help!
    Last Post: 03-03-2011, 03:20 PM
  2. FLA100 Kit Height Measurement
    By eaglezsoar in forum DIY CNC Router Table Machines
    Last Post: 08-14-2010, 12:02 PM
  3. 0.01 mm Tool Measurement
    By Leha_Blin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2009, 06:04 AM
  4. I need a measurement from a Sherline CNC kit...
    By vlmarshall in forum Benchtop Machines
    Last Post: 01-29-2009, 05:10 AM
  5. Accuracy measurement
    By freddrago in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2007, 11:45 AM
