Hi all, I'm new to the zone. I have a problem with a Niigata HN63C with a Fanuc 15-M control, it wont accept a G65, or any variable programming. Does anyone know what parameter it might be to enable macro programming? Thanks!![]()
"unknown G-code" alarm? if that's the case, you out of luck even turn parameter on 'cause u dont have macro option.
The best way to learn is trial error.
Thanks. Cheers!
You more then likely don't have macroB on your control but as a test program #1=5 in MDI mode. If you get an alarm then you don't have macroB. Let me know.
Stevo
Hey thanks, no it doesnt work, it says invalid break point of words. when ever i try to use any "IF" or "GOTO" words, it seperatets them into single letters. It's messed up, I have never ran a mill that didnt work with G65.
PM me your 9100 parameters and I will take a look at them. They should go from 9100 to about 9160 or so.
Stevo
Do you have a print out or hard copy of your 9000 parameters you can email?
Al.
Albert E.
Yes I have a copy of the machine parameters, and can email as well.
