603,923 active members*
2,254 visitors online*
Thread: gcode
Results 1 to 4 of 4
    Feb 2010
    gcode
    lazy cam wrote this gcode but mach3 finds error won't run them
    Attached Files Attached Files
    Feb 2010
    It would help to know what error that Mach3 is giving. It may not be a problem with the code itself but rather an issue with offsets or absolute values that are currently stored in Mach3.
    Feb 2010
    The error is RADIUS TO END OF ARC DIFFERS FROM RADIUS TO START , in the case of Bench side,LINE 33. This error is same for serial of gcode from lazy cam only of coarse line #
    Feb 2010
    I just found this post in the Mach3 forums. Hopefully this is will fix your issue.
    http://www.machsupport.com/forum/index.php?topic=1075.0
  1. svg to gcode?
    By b0j3 in forum OpenSource Software
    Last Post: 08-22-2007, 05:08 AM
  2. Gcode I think
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 10-27-2006, 12:52 AM
  3. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  4. GCode
    By rogerbureau in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-07-2005, 02:36 PM
  5. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
