603,958 active members*
2,258 visitors online*
IndustryArena Forum: Gecko Drives
Page 11 of 107 9101112132161
Threads 201 to 220 of 2139
Discuss all Gecko drives here and get direct support!
Sub-Forums Threads / Posts  Last Post
  1. G-REX
    (2 Viewing)
    Discuss G-REX here.
    Forum Actions:
    Forum Statistics:
    02-08-2008, 02:04 AM Go to last post
  1. Runaway with G320X
    Started by kemlin, 08-22-2017 03:00 PM
    encoder, g320x, power, provide, reading
    08-23-2017, 02:53 PM Go to last post
  2. 5 axis breakout board wiring PLease :'(
    Started by isowe, 02-27-2012 05:01 AM
    08-18-2017, 08:13 PM Go to last post
  3. Gecko g540 Y-axis causing fault
    Started by trottrr50, 08-05-2017 03:04 PM
    case, g540, gecko, plug, y-axis
    08-05-2017, 08:53 PM Go to last post
  4. different motors on g540
    Started by kiark, 07-25-2017 10:19 AM
    coil, motors, phase, power, resistance
    07-25-2017, 06:49 PM Go to last post
  5. Gecko G540 and Probotix Motors
    Started by pyrojon, 02-06-2017 11:17 PM
    07-18-2017, 11:03 PM Go to last post
  6. G320X fault while testing need a little advice
    Started by kemlin, 07-07-2017 04:53 PM
    drive, due, power, supply, voltage
    07-07-2017, 04:53 PM Go to last post
  7. ENCODER QUESTION
    Started by gabedrummin, 06-27-2017 05:09 PM
    encoder, error, motor, revolution, set
    07-05-2017, 02:50 PM Go to last post
  8. G540 VFD Output issue
    Started by nickfoocs, 06-14-2017 07:40 AM
    board, g540, linuxcnc, output, rpm
    06-25-2017, 09:23 PM Go to last post
  9. G320x Servo Drive Issues
    Started by FlyingDonkey, 04-18-2017 06:46 AM
    driver, encoder, g320x, motor, servo
    06-20-2017, 06:31 PM Go to last post
  10. 320X VIDEO
    Started by gabedrummin, 06-14-2017 04:21 PM
    320x, check, drive, gecko, video
    06-14-2017, 04:21 PM Go to last post
  11. Upgrade to gecko drives
    Started by Herptastic, 06-11-2017 10:28 PM
    36v, drives, gecko, notice, smooth
    06-12-2017, 06:30 AM Go to last post
  12. Hopefully a dumb question anot bnot wiring
    Started by kemlin, 06-07-2017 03:33 PM
    anot, bnot, cnc, drive, wires
    06-07-2017, 05:19 PM Go to last post
  13. dynamech conversion g540
    Started by miwaba, 06-06-2017 11:56 PM
    axes, dynamech, g540, red, wired
    06-06-2017, 11:56 PM Go to last post
  14. No load rpms on servos without specs
    Started by kemlin, 06-06-2017 03:39 PM
    correctly, mfg, rpm, servos, wired
    06-06-2017, 06:48 PM Go to last post
  15. Momentary push button as limit wsitces?
    Started by kfir762, 05-25-2017 09:08 AM
    cnc, limit, momentary, push, switches
    05-25-2017, 01:03 PM Go to last post
  16. G320X Setup and Tuning Videos
    Started by CoAMarcus, 05-18-2017 07:08 PM
    g320x, oscilloscope, setup, video, videos
    05-22-2017, 06:23 PM Go to last post
  17. Newbie needing some help
    Started by Truggys_Suck, 05-12-2017 06:47 AM
    box, cnc, software, stepper, switch
    05-18-2017, 10:54 PM Go to last post
    05-18-2017, 07:05 PM Go to last post
  18. Motor Sizing and Current Draw with Gecko Drives
    Started by NIC 77, 05-11-2017 12:05 AM
    cnc, current, g201x, motor, power
    05-11-2017, 01:50 AM Go to last post
  19. G540 spindle control.
    Started by krakenatwork, 04-01-2011 03:11 AM
    not, since
    05-08-2017, 05:12 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 9 users browsing this forum. (0 members & 9 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
