603,853 active members*
3,611 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Glacern Supported Linear Rails & Bearings
Results 1 to 8 of 8
    Aug 2007
    147
    Arrow Glacern Supported Linear Rails & Bearings
    Just letting everyone know that our 20mm and 30mm SBR supported rails and bearings are now in stock at http://www.glacern.com/sbr.
    They are currently at winter sale prices, and we're offering $4.99 flat shipping for orders over $99. We also have 30mm x 10 ft rails in stock, which ship by truck freight.
    These are first of many automation products that we plan to add to our catalog. We're particularly excited about these rails, as we feel they're ideal for folks building their own routers and plasma tables thanks to the low cost, availability, and ease of installation.
    We're fans of using aluminum T-slot extrusions for building CNCs since they're so easy to cut, join, and adjust. Our 20mm rails can be bolted directly to standard 60mm-wide aluminum extrusions (30mm T-slot spacing) without modification, while the 30mm rails can be bolted to standard 80mm-wide aluminum extrusions (40mm T-slot spacing). Likewise, the 20mm and 30mm rails can be adapted to "10 series" and "15 series" inch extrusions by simply drilling additional holes in the extruded aluminum T-support.
    -Sol
    Glacern Machine Tools
    Apr 2007
    47
    Could these rails be butted up against each other to make the overall length longer? Will you guys be supplying any longer 20mm rails in the near future?
    Is the $4.99 shipping for as much as you order that isn't freight?
    Jul 2003
    586
    do you make an adjustable block(truck)? looks good.
    Aug 2007
    147
    The rails can be butted up, but not straight out of the box due to the light chamfer ground on the ends of the shafts. Some careful grinding will be necessary. Yes, we can supply longer lengths in the future. What lengths were you interested in?
    The bearings can be adjusted with a set screw on the top of the block. We don't offer the clamping style on the side of the block at the moment.
    Thanks.
    Aug 2005
    135
    I've converted a Super X3 a while ago but I have been thinking of building gantry type machine to eventually replace the X3 with larger travel and quite frankly more precision (hopefully).
    Thinking I'd probably mount them on a steel tubular frame filled with concrete or E/G.
    Do you think these type of rails would suit such a machine or are they for lighter work such as a router?
    Mar 2008
    177
    Question
    Do you have 30mm X 3050mm rails in stock Cost?
    Gene Crain
    www.plantasymaderas.com
    Mar 2005
    187
    Any chance of you guys carrying a linear bearing/rail of the roller type, similar to the Hiwin RG Series?
    Thanks!
    Andy
    Aug 2007
    147
    Quote Originally Posted by EBC View Post
    Gene Crain
    Yes they are in stock at $249.99 each. Please email us for shipping, thanks!
    -Sol
  1. Intermittently Supported Linear Ball Bushing Rails
    By Chuck_M in forum Linear and Rotary Motion
    Last Post: 12-13-2009, 05:57 AM
  2. 16mm vs. 20mm supported linear rails...
    By WilliamD in forum DIY CNC Router Table Machines
    Last Post: 12-20-2008, 12:37 AM
  3. Linear Rails and Bearings
    By Robyn in forum News Announcements
    Last Post: 08-30-2006, 04:10 PM
  4. Linear Rails/guides and Bearings - What size is best?
    By Shawnusa in forum Linear and Rotary Motion
    Last Post: 10-29-2005, 04:51 PM
  5. Linear rails and bearings- overkill?
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 01-30-2004, 10:43 AM
