603,943 active members*
2,911 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Intermittently Supported Linear Ball Bushing Rails
    Nov 2009
    15
    Question Intermittently Supported Linear Ball Bushing Rails
    The catalogs for Linear Ball Bushing rails typically show either end supports suspending a rail for a closed carriage, or continuous supports with an open carriage. The continuos supports add significantly to the cost, but are required to control the deflection that would occur over long unsupported spans.
    Is it acceptable to use short closely spaced supports of the continuos type to control deflection, and significantly reduce the support costs of the continous support? I seem to recall seeing this in a picture for a large commercial plasma cutter table.
    Mar 2003
    35494
    Quote Originally Posted by Chuck_M View Post
    Is it acceptable to use short closely spaced supports..................
    You didn't say what you are using them on, but probably. As long as the shafts can't flex between the supports.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. In progress - 8020, linear rails, ball screws, steppers
    By stevespo in forum CNC Wood Router Project Log
    Last Post: 07-25-2012, 05:10 PM
  2. Linear supported rail source
    By CNC Brute in forum DIY CNC Router Table Machines
    Last Post: 07-03-2012, 05:34 PM
  3. who sells fully supported rails?
    By SatanKlawz in forum Linear and Rotary Motion
    Last Post: 06-20-2012, 09:06 PM
  4. Building with supported rails?
    By jeeybee in forum DIY CNC Router Table Machines
    Last Post: 10-24-2009, 03:38 AM
  5. 16mm vs. 20mm supported linear rails...
    By WilliamD in forum DIY CNC Router Table Machines
    Last Post: 12-20-2008, 12:37 AM
