Thanks for the info. That was a bug that crept in during a change.
I just uploaded a new version V4.1.19. It should work again with that.
There should also be some other improvements for lathe operation in it.
First off all I want to give you big kudo's on the quality of this program! It is awesome!
I have been using it since version 3.49.14 in which Tangential Knife was introduced.
In that version there was a settings "accuracy 2D" in which you could influence the accuracy that will be used to create circles and arcs. The default value was 0.1 but I always used it with a value of 0.005 for smoother curves.
Today I upgraded to version 4.1 and I see that this settings is no longer available. All the files I make now have I think the default value of 0.1 which results in not so smooth corners.
Is there a new parameter to changes this behavior?
Tnx!
Release notes V4.2
once again there is a new GrblGru version V4.2. This time most of the changes have been made for the lathe operation.
In the video I tried to describe the most important changes.
Have fun with GrblGru
@yannicovicz
How did you create the circles ?
Did you load them from a DXF or SVG file into GrblGru, or did you use the 2D templates.
Can you please provide me with a file so I can see what the problem is.
@GrblGru
I did a test with a spiral SVG which I made in InkScape.
The generated Gcode "cuts" the spiral in sections, but the Angle steps are rather large, especially when you go to the inside of the spiral. If I cut that, then it is no longer an arc but more a polygon.
In the previous version (the one with the first release of the tangential knife you posted here) there was a settings in which you could influence the resolution of the arc to polygon conversion, but in the newer versions it is no longer there.
I also tested it with a DXF, the behavior was +- the same (it was another shape so I can not compare it 1:1 with the SVG)
Hello!, hope everything is going ok!
Just to report a bug (sorry if repeated):
v4.1.13
-Something happens (randomly, no pattern noticed) with milling direction indicator. Attached png for reference. All these shapes were on same job (only 1 milling direction, CCW), some of them are reversed. Seems to be just for presentation, as worked as expected in reality.
Best regards.
JC
@yannicovicz
Sorry, I just saw that I have not answered you yet.
Have you been able to solve the problem in the meantime ?
The parameter "Polyline cleaning" influences the accuracy. But only if the switch "Convert all to polylines" is set.
Please provide me with an example file. Then I can help you better.
@jcorona
Thanks for the feedback. Can you please provide me also best a project file.
It is always much easier for me to reproduce the problem.
Hello GrblGru,
In version 4.2.5 there are 2 BUGs in imports of *.SVG and *.GCODE
Armando
Hi RobinMorritt,
This is not related to the change of directory, No!
it's a BUG
Armando
Ah, OK. Let's hope it's an easy fix for Mr GrblGru.
Hi everyone.
Today I installed new version 4.2.7 of GrblGru.
Still with BUG on importing SVG and GCODE see attachment.
Armando
@GrblGru
Hello, I'm doing a new translation to Portuguese Brazil and I'm having problems in the part of displaying the tables (#list: job_templates) presenting CreateGrid() and RefreshMyGrid() errors. Unable to display data. Was any part of the translation responsible for this error?
I would also like to know if it would be possible to make a portable, without copying the files to the ProgramData folder.
I don't know if it's already been mentioned, but those who work with small screens don't have the possibility to increase or decrease the drawing area in the 2D tab.
Tested in versions:
4.2.0
4.2.12
Hi sevenbsb, I did a translation to Brazilian Portuguese. and did not messed with any program code. Just anexed the text to other translation, as told by Gary.
Can't see how it would cause problems.
I will check the program and see if I can reproduce your error.
Cheers, Dimitrios
@sevenbsb
can you please make your file available here. Then I can see what the problem is.
@Dimitrios
thanks for your help
@GrblGru
The translation files I have so far are these
@Dimitrios
Yes, I did the translation based on yours, which is already in the program, I think it was on 09/28/2019, and it had the same problem.
I also had some untranslated parts, for version 4.2.0, so I decided to improve.
@GrblGru
@Dimitrios
I made a video showing the error
One more information when generating the GCODE with the V_CARVE job (#jobmainmode = V_CARVE ) does not generate the M3 command to turn on Spindle, in other modes this is normal
Version 4.2.0
