603,310 active members*
2,407 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > GrblGru: Free CAM and 3D-Simulation for mills and lathes
Page 39 of 40 2937383940
Results 761 to 780 of 795
  1. #761
    May 2016
    354
    Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    Ok, now I've finally got it Thank you for convincing me
    The paths are calculated from the center of the tool, not from the tip. If the infeed is smaller than the radius, the green paths appear below the start line.
    And you are right, this is of course a bug that I need to fix.
    But please give me time. I have a lot to do at the moment and the error is not that serious. It won't break anything, it just needs time.
    Thanks for your help to improve GrblGru
  2. #762
    May 2016
    354
    Hello everyone,
    I finally got around to finishing the last part of the little series about the foam cutter.
    Have fun with it
    https://www.youtube.com/watch?v=A7OwV6jxwE4
  3. #763
    Hallo , How I can change Z and X order of machine ? Spindle moved on X platform and X driven by Z axis. Y is table axis
  4. #764
    May 2016
    354
    You can map all axes in the MachineManager.
    To do this, simply enter the desired letters in the right column. After that, do not forget to press the ‘Accept data’ button.
    Note that the designations are only changed in the communication with the controller. The displays in the GrblGru window remain unchanged.
  5. #765
    May 2016
    354
    From the new version v6.0, GrblGru now also offers the option of creating simple geometry objects such as circles, arcs, rectangles and polylines.
    In the video I briefly introduce the various functions.
    https://www.youtube.com/watch?v=nOjkfjgK5Ko
  6. #766
    Apr 2025
    3
    Hi GRBLGRU
    I just finished my mini lathe.
    I use DCMT insert with 0.2mm radius.
    I realized the diameters are undersized.
    When I change the Corner radius to 0.2 in the tool tab, the contur goes under the real dimension.
    No issue above 0.2mm.
    Your help is very appriciated.
    Awesome tool!
  7. #767
    May 2016
    354
    Thank you for your feedback.
    I have uploaded a corrected version on my website under “Beta version V1.3”.
    Please check it out.
  8. #768
    Apr 2025
    3
    Super! Works perfectly now. I very appriciate your help. I hit the DONATE button.
    Thanks again!
    https://www.youtube.com/shorts/JzzFHKP6PAc
    Quote Originally Posted by GrblGru View Post
  9. #769
    May 2016
    354
    Hey, I'm glad to hear that.
    Great machine and great video !
    Thanks also for the “Donate cutter”
  10. #770
    Apr 2025
    3
    Great!
    I enjoy turning with your CAM.
  11. #771
    May 2016
    354
    I've been making more videos in German again recently.
    Perhaps this one is also more generally understandable and interesting for some people.
    https://www.youtube.com/watch?v=sNQGGU54ZRY
  12. #772
    May 2016
    354
    Re: GrblGru Troubleshooting
    Another video in German, which also illustrates without text how to machine turned parts on the milling machine.
    It also shows how you can use your milling machine as a lathe.
    https://www.youtube.com/watch?v=K3SOQTMF6bw
  13. #773
    Jan 2024
    8
    Should this update also fix the bug from post #761 or is that a separate issue? I just tested 1.3 and still see the same result.
  14. #774
    May 2016
    354
    @54baseball
    Sorry, I don't understand you. There is no bug described in #761. Are you talking about the milling or lathe program?
    Can you please describe your problem in detail again ?
  15. #775
    Jan 2024
    8
    Thank you - sorry for not being more clear. Here is the comment that I was referencing. I am seeing the same behavior in lathe beta v1.3.
  16. #776
    May 2016
    354
    @54baseball
    Sorry, I must have forgotten that. Thanks for reminding me.
    I just uploaded a new beta V1.5.
    Please check if everything is correct now.
  17. #777
    Jan 2024
    8
    Thank you, that did the trick. Well deserved donation incoming.
  18. #778
    May 2016
    354
    As a supplement to my last, more theoretical video, today I would like to show you milling turning in practice. I have chosen a chess piece as a test object, which is intended to represent a possible area of application. Based on the experience gained in the tests, I had to make significant changes to the entire process. (V6.10)
    Although milling turning is certainly no real competition for turning on a lathe, I am pleasantly surprised by how well it works. There are a lot of small turned parts, such as game pieces, handles, furniture knobs, etc., that can be produced very well with this method.
    In addition to the familiar possibilities of a turning axis, milling turning thus offers another convincing argument for sensibly expanding the range of applications of a conventional 3-axis milling machine.
    Unfortunately, the video is only available with German subtitles. I would be very happy if someone would try out milling turning and perhaps even make a video of it.
    Maybe even in English.
    Have fun with GrblGru
    https://www.youtube.com/watch?v=E_b1UC2cACg
  1. Affordable CNC Mills and Lathes
    By cweber in forum Uncategorised MetalWorking Machines
    Last Post: 04-20-2013, 10:44 AM
  2. D&M Lathes, Mills, etc.
    By boatlover in forum Benchtop Machines
    Last Post: 04-25-2008, 02:39 AM
  3. Birmingham Mills and Lathes
    By smilenbseen in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2007, 01:19 AM
  4. Birmingham Mills and Lathes
    By smilenbseen in forum Vertical Mill, Lathe Project Log
    Last Post: 01-02-2007, 01:42 AM
  5. Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW!
    By mxtras in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2006, 07:43 PM
