I'm looking at building something along the lines of what they show on CNCRouterParts, using a 1018 cold-rolled steel flat bolted into the 8020 to run bearing wheels on.
I want to build at least an 8ft X-axis. 8ft is a common size for a steel flat, but it won't do because the carriage itself has some width, and you want some margin to work with 8ft plywood, the bit needs to be able to cut past the end of the sheet.
Can multiple pieces be joined? It does seem like kind of a bad idea, although the basic stiffness is being provided by the 8020, still, the discontinuity seems like a problem since that surface is both supporting and guiding the gantry weight. The bearings could wear on the interface and it may be inaccurate near there.
