587,218 active members*
2,927 visitors online*
Page 7 of 8 5678
Results 121 to 140 of 151
  1. #121
    Apr 2010
    215
    Re: Gully's new 3x3 steel CNC router build
    Victory is at hand!
    While I was convinced I had a fault develop on my breakout board, I tried Pippin88's suggestion of changing the pulse width on the direction for the Z axis
    Magically it now works again. Thanks dude, I appreciate your input.:cheers:
    And also winning at work today. Was about to head off home and what do I see on the discarded equipment heap. A slightly battered but still serviceable C.O.W stand (computer on wheels)
    similar to this
    Attachment 463054
    Needless to say that is now in my workshop awaiting repairs and conversion to Gully's CNC COW
    Gully
    Striving for medeocrity..and achieving high scores!
  2. #122
    Jan 2008
    1538
    Glad I could help.
    If drivers etc are the same, it's possible there is a slight difference in the breakout board outputs and your previous timing settings were right on the edge (guessing, not an electrical engineer).
  3. #123
    Apr 2010
    215
    Time poor at the moment.
    But have managed to complete repairs, make and paint the parts needed to get the C.O.W. sorted
    So its ready to rock as of now, just need to finish off a bit of wiring when the last of the parts arrive then complete the Mach3 calibration
ID:	463694 Click image for larger version.
    Only have 2 small parts left to cut on my Joe's for this machine. Once they are done and I'm happy that the little Dell PC is up to the task, It will be time to
    relocate the spindle to it's new home and push this puppy over the finish line.
    Gully
  4. #124
    Apr 2010
    215
    Bit despondent tonight.
    Thought I would tidy up the steps per unit calibration only to find the issue with the Z axis has returned
    No amount of messing with the pulse width and direction settings would get it to work correctly again, so I'm back to the drawing board with that little gem.
    Will ponder on it till the weekend as I'm too tired and p@##%d off with it now.
    Suspect I will swap out some parts again to see if that has any effect.
    Suggestions on a solution still welcome
    Gully
  5. #125
    Apr 2010
    215
    Back in lock down (again) Go figure!
    So it's back onto the Z axis issue. (Fun times). Did a heap more testing with both fresh reloads of mach3 and a different PC also ran the Z axis through my spare gecko drive plus a heap of other tests and everything is leading back to an intermittent fault from the breakout board on the Z output.
    Currently I have it working "reliably" but have no faith in this particular BOB, so for peace of mind the plan is to swap it out with my Joe's BOB after I cut an adapter to hold my dial indicator for setting up the spindly square to the
    spoil board.
    https://youtu.be/zHzgbY0jIdw
  6. #126
    Apr 2010
    215
    Had a good day today, moved the spindle and VFD over to the new beast and am pleased to say it is all working as it should.
    Even had time to tram the spindle to the table as well. Just need to finish up and level the spoil board top and we are at practical completion
    Attachment 465192 Attachment 465194
    Ignore the dates on the pics, I seem to have turned on the time date stamp that has never been set up
    So my Joe's cnc is officially retired as of now. Its parts will hopefully live on in future projects. Checked it's maintenance hours log today, It has clocked up just under 2800hrs. of use.
    No wonder the skate bearings are sounding very average.
    Guess next post will be when its totally finished and making dust
    Thanks for coming along for the journey.
    Gully
  7. #127
    Apr 2014
    432
    Nice to see you got it all up and running can be frustrating for sure you have had a journey that's the best part .I have just put an ESS on all good I like how they work , but now the little laser diode I was using cant control the intensity of it anymore Oh well search away .
  8. #128
    Jul 2018
    6461
    Hi Gully - Well done. 2800hrs over how many years? When do you make sawdust? Peter
  9. #129
    Apr 2010
    215
    Thanks InMesh
    Thanks Pete,
    From memory, I completed the Joes in 2011. So it's given me around 10 years of mainly hobby project / machining enjoyment.
    It has been a very robust and reliable little machine, It really only needs new bearings and a tidy up and I'm sure it would go another 10.
    Making sawdust is probably going to be in July. I need to spend some time cleaning out the workshop ( I'm sure I'm a border line hoarder of stuff I don't need), and move some other equipment
    around so I can get the new machine into its allocated spot.
    Gully
  10. #130
    Apr 2010
    215
    Spent a couple of hours out in the freezer (AKA workshop) each night after work this week to tidy up all the little jobs that were left
    Spoil board top is on and ready to level
    Added a couple of relays to start/stop the spindle and dust collector via mach3. At this point only the dust collector is hooked up and working
    I will manually start stop the spindle until I'm comfortable all is good.
    Swapped out the breakout board with the one from my Joe's a week or so ago and had no sign of issues with the Z axis since (touch wood)
    Best bit was today, spent the day moving stuff around in the workshop and have relocated the machine to its new home.:cheers:
    Attachment 466294
    At this point I can push material up to 2200mm long through before I hit the wall.
    Need to still mess around with the vac hose and fittings to get it to work nicely over the cut area.
    Gully
  11. #131
    Jul 2018
    6461
    Hi Gully - excellent update. I know a machine is never "finished" but when are you declaring it finished? Peter
  12. #132
    Apr 2010
    215
    Thanks Pete,
    Your right they are never really finished, just machines we build for enjoyment/work that are in on going stages of development
    This one is at the end of stage 1 development, So I'm "finished" (Yeah right!)
    Gully
  13. #133
    May 2015
    686
    Great work coming to a finish. I read the whole thread last night wondering what the spindle specs were that you are going to be using and drew a blank.
    You never know, I might be tempted one day to build something with a spindle instead of a plasma torch!
    Rod Webster
    www.vehiclemods.net.au
  14. #134
    Apr 2010
    215
    Hi Rod,
    Thanks.
    The spindle is an air cooled 1.5Kw unit with an ER20 collet, driven by a HY 1.5Kw VFD purchased on Aliexpress
    It's a bit small for this machine but it was originally purchased for my small Joe's CNC,
    P.M. me if you would like the sellers details
    Strangely, I have been tempted to build a little CNC plasma cutter from the spare parts my Joe's is donating back
    Gully
  15. #135
    May 2015
    686
    Quote Originally Posted by rodw View Post
    Gully thanks. I'm a bit like you. I have almost everything except the spindle floating around. Including a 5.5 kW VFD. But time is an issue....
    Some of the BT30's with ATC look interesting in that category.... But not quite in the DIY budget category.
    Plasma building time would be a good time for you to experiment with Linuxcnc. A Mesa 7i96 and THCAD-10 would set you back < USD $200 and perform better than any of the external THC's used with Mach.
    I use a Mesa 7i76e which adds more I/O (32 inputs, 16 outputs and 4 analog), 2 x MPG inputs and Spindle control and I have a spare here asking to be used...
    Rod Webster
  16. #136
    Apr 2010
    215
    Have managed to find time to make a tidy little vac system for the CNC
    Works via an overhead pivot arm that just swings back and forward as required.
    All the crap goes through my home made cyclone separator that catches 98% of the booty. Only a small amount of very fine dust seems to make it into the vac hopper its self.
    Also leveled out the spoil board.
    Happy days.
    Attachment 467602 Attachment 467604 Attachment 467606
    Gully
  17. #137
    Jan 2008
    1538
    Good to get decent dust extraction going. That's what I've been working on. I'm going 150mm / 6" all the way to the bit.
    Your dust boot looks like it narrows severely and will restrict flow.
    Dust collectors are high volume low pressure and can't cope with restriction
    Vacuum cleaners are low volume high pressure and can cope with some restriction but never move enough air to capture fine dust (the stuff that matters for health)
  18. #138
    Apr 2010
    215
    Hi Pippin88
    You have a good eye. The Aliexpress dust shoe does narrow down to about half the area of the 100mm pipe which I agree isn't ideal
    But it is clearing the cut area OK and the duct work doesn't appear to be holding an excess of mess, so the suction side of things while it could always be better
    is working ok.
    I am looking to upgrade both the vac unit and the dust shoe in the near future
    Gully
  19. #139
    Jul 2018
    6461
    Hey Gully - I'm about to start thinking through my next machine. Its called Frankenrouter. It will use as may bits as possible I have lying around that have been used and not used etc. I'm going to use round rails as the idea is to do it as cheap as poss. Maybe a full sheet size machine. Current thoughts is half sheet. Any do and don'ts with these? Good suppliers or poor or good specs etc? I've only used square rails in the past.... seems round is about half the price of square... Regards Peter
  20. #140
    Apr 2010
    215
    Hi Pete,
    Your a man after my own heart. sounds like one of my budget builds
    From experience, having operated commercial routers before, If you want to be able to machine right out to the edges of a 1200 sheet the bed area would need to be around 1400mm.
    Personally on a machine that big would probably go rack and pinion or a larger diam ball screw than 16mm, (was tempted to go R&P on this build)
    I have found the round rail to be fine, Just go bigger diam than you think you need.
    I can PM you a list of where I got my parts from if you want
    Will be following along when you get going
    Gully
Page 7 of 8 5678
  1. Router home build Australia. Solid steel build
    By 80gus in forum DIY CNC Router Table Machines
    Last Post: 05-03-2020, 09:24 AM
  2. Diy steel router build
    By mkc2 in forum Australia, New Zealand Club House
    Last Post: 03-11-2014, 02:20 AM
  3. Steel 1.2m*1m Router build
    By Jtepper in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 08:20 AM
  4. New 4x8 Steel CNC router build
    By Ernie34 in forum DIY CNC Router Table Machines
    Last Post: 11-25-2012, 01:41 PM
  5. First Router Build - 4x4, steel, R&P
    By cxixer in forum CNC Wood Router Project Log
    Last Post: 02-09-2008, 09:15 PM
