603,855 active members*
3,979 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > haas 4th axis how to make it rotate 90 will doning a tool change
    Aug 2011
    77
    have a ton of parts to run and looking to save as much time a possible on machine
    running a hrt 210 haas 4th on a haas vf4 when doing a tool change can I have it rotate 4th axis at the same time so when its done doing tool change it cone go right to milling
    I tried putting the A move on the same line as tool change that did not work
    but thought there was a way to do this that I read somewhere
    thanks for any help
    Nov 2006
    490
    Re: haas 4th axis how to make it rotate 90 will doning a tool change
    Haas lathes have an option for this but I don't think it's possible on the mill. The M-code is executed after the rest of the codes on the line have completed, including XYZABC movements. You can save some time by performing a tool change without commanding a Z move or spindle stop, but those are artifact of the control doing it automatically when performing a tool change.
    If there's a way to fake it I'd love to find out!
  1. haas vf2 tools jam up on tool change
    By allenp in forum Haas Mills
    Last Post: 07-21-2016, 06:05 PM
  2. haas tool change
    By owassomachine in forum Haas Mills
    Last Post: 09-17-2015, 08:24 PM
  3. Replies: 0
    Last Post: 02-14-2010, 07:26 PM
  4. Help me make a quick change tool post decision please
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 01-27-2009, 01:43 AM
  5. How to make Tool Change and add on device?
    By jimmychand in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2007, 12:16 AM
