603,963 active members*
1,775 visitors online*
Results 1 to 4 of 4
    Oct 2006
    24
    How to make Tool Change and add on device?
    I need help on G-code or M-code for signal out and signal in to make Tool Chand and other add on device. Basically, I need a G-code or M-code to give signal out, machine should stop at the time. Once the device finish then it should give signal in and the rest of the G-code in the program should continue.
    Please help or please teach if there other way to do it.
    Thank in advance for your helps
    Apr 2005
    3634
    Video (Tool Change)
    A) http://www.machsupport.com/Videos/To...ol_Change.html
    B) http://www.machsupport.com/artsoft/videos.htm
    Download (Tool Change Macro - Zip File)
    http://www.machsupport.com/Videos/M6Start.zip
    Note:
    The Flash video, wouldn't play for me.
    Apr 2005
    3634
    This link works, for the tool change video. Click on "Tool Change" 3rd from bottom, on the left side of the screen.
    http://www.machsupport.com/Videos/Ma...elections.html
    Jul 2007
    67
    I've posted a file toolchange.zip which uses the new Brain in Mach3
    Here at http://www.machsupport.com/forum/ind...ic,4743.0.html
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. tool change
    By jrick in forum Commercial CNC Wood Routers
    Last Post: 01-14-2007, 12:01 AM
  3. Tool change
    By lilricky2 in forum BobCad-Cam
    Last Post: 06-03-2006, 07:00 PM
  4. tool change
    By Dwallace in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-24-2005, 07:17 PM
  5. Tool Change
    By WOODKNACK in forum Uncategorised CAM Discussion
    Last Post: 07-13-2003, 03:26 AM
