603,780 active members*
3,209 visitors online*
    Jun 2013
    Haas S5C indexer
    We purchased a used Haas S5C indexer and when we set it up on the bench it seemed to work all right. But if we touched the cable from the Haas controller it would start and stop by itself, run at high speed or stop. Problem is with cable at indexer end. Took it apart to find wires between encoder and cable had been cut and only been tied not soldered. Some one must have replaced the motor or encoded and had a different connection. Any way when we took it apart it all fell apart, we don't know which wires went where.
    The Haas Connector has 6 wires Red, Black, White with Orange stripe, White with Red stripe, White with Yellow stripe, White with Brown stripe.
    Encoder has 8 wires, Black, White, Green, Orange, Red, Yellow, Blue, Brown.
    Can anyone help us with how the wires should match up, What color to what color?
    Encoder is marked Renco Encoders Inc. and motor is Haas part # 93-5102 Reliance Electric. This is a brush motor.
    Feb 2010
    1184
    See if this helps.
    Attached Files Attached Files
    Jun 2013
    Thanks for the drawing but i need the diagram for the encoder wires to the drawing you provided.
  1. disassemble Haas 5C indexer
    By ken fedirko in forum Haas Mills
    Last Post: 01-09-2024, 02:59 PM
  2. Haas 5c indexer help!
    By cmacclel in forum Haas Mills
    Last Post: 04-11-2013, 11:46 AM
  3. haas indexer
    By Jfrahm in forum Fanuc
    Last Post: 12-15-2010, 09:13 PM
  4. Haas Indexer
    By binzer in forum Haas Mills
    Last Post: 12-16-2009, 03:10 AM
  5. Haas VF1 & 5C Indexer
    By lovell110 in forum Haas Mills
    Last Post: 12-08-2007, 06:39 AM
