587,303 active members*
3,780 visitors online*
    Feb 2006
    476
    Heidenhain encoder
    I am trying to get information on an encoder. It is a Heidenhain ERO.
    The encoder is marked:
    ERO 120 500 F10
    iDNr 220 155 10 sNr 1551729.
    I looked at Heidenhein's web site with no luck. I have emailed them but they will not be open until Monday and I would like to work on them before then.
    I am trying to find out the voltage, count, and current draw.
    Vince
    Aug 2006
    93
    Dear N4NV
    it must be ERO 1200 series ! - line countfrom 1024 and 2048 for ERO 125 ( TTL) and same for ERO 1285 sinsodual 1vpp .....and 1024-2048-5000 for ERO 1324 (TTL) and ERO 1348 Sin1Vpp.....Mechanical RPM 25000 rpm...supply 5 Vdc.. do you want drawing ?... let me know whats your problems ?
    Apr 2009
    3
    This thread is old, but I can add information so someone that has a similar problem can be more informed.
    The Heidenhain ERO 120 is on SEM servo motors. This particular unit is a 500 line count encoder (signified by the "500" after the "ERO 120"). Outputs are far less than 1 V peak to peak. 15-17 micro according to the encoder label. Supply voltage is 5Vdc.
    These are not available new from Heidenhain. You would have to contact SEM for replacement options. Of course there is a good company that repairs these routinely that can be found on the internet.
  1. Bridgeport series 1 cnc/Heidenhein TNC 131controls
    By boringmill in forum Bridgeport / Hardinge Mills
    Last Post: 10-09-2011, 01:23 PM
  2. BP Interact 412 Heidenhein 351
    By besc in forum Bridgeport / Hardinge Mills
    Last Post: 10-14-2006, 05:08 PM
  3. Bridgeport Series II Interact 4 & Heidenhein Problems
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2006, 08:27 AM
