603,810 active members*
3,109 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > HEIDENHAIN > HEIDENHAIN -> TNC > Heidenhain TNC 410 Error C310 Z1 TRACK X ERROR
    Mar 2010
    72
    I have a problem with my Heidenhain TNC 410 Milling Machine
    error # C310 Z1 TRACK X ERROR
    All cables and drives are OK.
    I changed pulse encoder but still i have the same error. Can anyone help me
    Nov 2008
    69
    Re: Heidenhain TNC 410 Error C310 Z1 TRACK X ERROR
    The problem is on the encoder inside the motor.
    That is either broken or contaminated. Needs to be adjusted correctly.
  1. Chevalier VMC - error C310 Z1 TRACK A ERROR
    By john robertson in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2015, 01:45 AM
  2. Chevalier VMC - error C310 Z1 TRACK A ERROR
    By john robertson in forum Employment Opportunity
    Last Post: 05-06-2015, 10:04 AM
  3. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  4. EZ track drive error
    By arhctysv in forum Bridgeport / Hardinge Mills
    Last Post: 05-16-2011, 05:16 AM
  5. BP Heidenhain error
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 10-09-2010, 05:04 PM
