603,946 active members*
2,220 visitors online*
Hybrid View
seraum Heidenhain TNC426/430M boot... 08-27-2024, 04:28 PM
cncmakers001 Re: Heidenhain TNC426/430M... 08-28-2024, 02:57 AM
seraum Re: Heidenhain TNC426/430M... 08-28-2024, 10:58 AM
    Sep 2007
    35
    Heidenhain TNC426/430M boot error
    Hello,
    I have a machine with TNC 430M.
    at startup, the machine loads normally. Just before posting the usual message to remove the emergency stop, a message is displayed:
    OPERATING PARAMETERS ERASED
    and there, the machine stays like that for about 5 seconds then restarts by itself, and this in a loop.
    I exchanged the hard drive with a clone but still the same message.
    I changed the backup battery, formatted the hard drive then reloaded the setup from the website, still the same message.
    If I delete the MP file from the boot menu, at startup I have the same message but the screen goes into edit mode and displays the parameters menu, but as soon as I save, the machine restarts and gives me the same alarm.
    Has anyone had the same problem?
    any ideas on the origin of the problem and how to solve it?
    Thanks in advance.
    Re: Heidenhain TNC426/430M boot error
    Quote Originally Posted by seraum View Post
    Hello,
    Thanks in advance.
    Maybe the tool changer sensor has problem, you can check with it.
    Sep 2007
    35
    Quote Originally Posted by cncmakers001 View Post
    Hello, Thank for the reply.
    I try to boot only with keyboard pannel, LCD screen and powersupply and get the same error. So all the I/O, siemens drive disconnected change nothing.
  1. Zayer milling m/c with Heidenhain TNC426
    By balavishe in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2024, 04:52 AM
  2. Y axis vibration HEIDENHAIN TNC426
    By Nil27 in forum German
    Last Post: 11-28-2018, 07:48 AM
  3. Handlewheel problems tnc426 heidenhain.
    By pachanga in forum DNC Problems and Solutions
    Last Post: 12-25-2014, 08:29 PM
  4. Heidenhain TNC410 and TNC426 or alternative?
    By Stuki-5 in forum BobCad Post Processors
    Last Post: 05-06-2014, 10:11 AM
  5. Problem getting thread milling to work on Heidenhain 430M
    By StewCNC in forum MetalWork Discussion
    Last Post: 03-31-2014, 12:53 PM
