587,665 active members*
4,049 visitors online*
Results 1 to 4 of 4
    Apr 2012
    heidenhein mill parameters
    I have a Kingston vmc, converted to cnc by a guy named woody in Calif. The machine has heidenhain 310 controls. I ran the machine at work for a few years and bought it when they replaced it. I didn't power it up for about 4 mos and it lost all parameters. Then I found out they never copied the parameters and woody has retired. I got the machine back to English, when it poweres up everything seems normal except the screen to reference axis doesn't come up. Anyone have a similar machine with copy of parameters? I really need some help.
    Nov 2012
    salvation
    I'm working on a machine fermat 5axis iTNC530, I want software that gives HEIDENHAIN format. (*. H)
    thank you in advance
    Jan 2009
    265
    You gotta do some homework because if you type in values that are not correct you can have more trouble than previously.
    Write ALL the values down before changing,
    change only one at a time,
    qualify the change has worked,
    revert to old value if not.
    i remember secret passwords were required for heidenhain to access all the values.
    i think NET123 accessed the network settings.
    Their are other 6 or so other passwords, i forgot, it's been 7 years ago.
    PAR456 ??? maybe?
    Nov 2012
    31
    We've two Parpas VMCs i.e. THS100 & XS32 with Heidenhain control. We need to create the backup of their Hard Drives as the Hard drive of THS100 got failed June this year. It took about two months from their to get new Hard from Parpas.
    Can any body suggest how to create a backup disk by cracking SIK protection? I think the version is iTNC530.
  1. Bridgeport series 1 cnc/Heidenhein TNC 131controls
    By boringmill in forum Bridgeport / Hardinge Mills
    Last Post: 10-09-2011, 01:23 PM
  2. mastercam x TNCremonT HEIDENHEIN
    By pachanga in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-24-2009, 03:34 PM
  3. Heidenhein TNC2500
    By nrpt in forum Controller & Computer Solutions
    Last Post: 03-26-2009, 08:40 PM
  4. Iso Heidenhein programming
    By tusharr in forum G-Code Programing
    Last Post: 10-13-2008, 12:24 PM
  5. BP Interact 412 Heidenhein 351
    By besc in forum Bridgeport / Hardinge Mills
    Last Post: 10-14-2006, 05:08 PM
