603,349 active members*
3,727 visitors online*
IndustryArena Forum > CAM Software > CamBam > Help creating tool paths in cambam to cut a sloped pocket
Results 1 to 10 of 10
    Sep 2013
    6
    Hello All,
    I am new to the CNC world and built my first Shapeoko CNC. I am trying to machine a pocket with a slope to it. The wood is 3/4" thick and the slope of the pocket would be from the surface down at the deepest end to .5625" leaving 3/16" of wood at its deepest point.
    I have attached a screen shot from my rendering in sketchup
    Any ideas would be very much appreciated.
    Thank you for your help...
    Regards,
    John
    Sep 2013
    6
    I have the latest version of CamBam, that is the only one i have at this time.
    Nov 2008
    51
    The through pocket can be done with a pocket mop(machining operaton). I would leave some stock then do a profile with leadin and out to finish. The slope pocket will be done with a 3d toolpath. I sugest a waterline process with a flat or square end router bit. Then a finish pass with a ballnose router bit if you can live with a radius in the corner, using a horizontal or vertical 3d process. and do the through pocket First load the 2d drawing in cambam and do the through pocket. Then open Cambam again and rename and load the model for the 3d process on the sloped pocket. You can post the .cb fileshere and someone should be able to help. Note the 2d file will be loaded in cambam as .dxf file and the 3d file will load as a .stl file. They both are saved from cambam as a .cb file.
    Sep 2013
    6
    Wow, thank you very much coolant slinger for your detailed response. I will work on setting up those operations and post the .cb files here for review.
    Regards
    John
    Sep 2013
    6
    I separated the pieces and have cut the through cut just fine but the slope is still giving me issues. In CamBam importing the .stl fie looked great, I setup a 3D toolpath Waterline process set with a region fill of Vertical Hatch and when i generate the tool paths it looks correct but when i run it on my cnc it just cuts a hole straight through with no slope. I am attaching my .cb file for review and any assistance...
    Thank you all for your time ...
    Regards,
    John
    Attached Files Attached Files
    Nov 2008
    51
    John,
    I am not having any luck with the toolpath on your part. But, I am not the most skilled at 3D with Cambam. If you don't get any help here try posting on the forum link below. It is Cambam's forum. The guys there do a lot of 3d with Cambam and respose time is usually a few hours or less.
    http://www.cambam.co.uk/forum/index.php?action=unread
    Reguards,
    Coolant Slinger
    Sep 2013
    6
    Thanks Coolant Slinger,
    I have registered on the CamBam forum and am still waiting for the admin to accept me, been a few days now with nothing from them so still waiting so I can post on that forum.
    Thank you for your time and effort ..
    Regards,
    John
    Oct 2008
    17
    Why not tilt your work peice ie blocks under one side...or in cam bam rotate the model save it making the part first then the pocket?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    Sep 2013
    6
    I figured out my issue with creating a pocket with a sloped bottom and wanted to share my findings with this forum.
    There is a VBScript that is on the CamBam website for generating a sloped surface and you can find the info here:
    CamBam reference library - Sloped Lines
    Hope this helps anyone else ...
    Happy Holidays to All and Thank you to those who gave me feed back on this thread.
    Regards,
    John
    P.S. Attached a photo of the finished part showing the sloped pocket.
    Oct 2008
    2205
    I would probably have done it with a 3D oeration rather than the plug-in, but the plugin was written because there was a high mumber of people asking to do this sort of thing. The script works, but, "Width : The width of the surface to cut. Use 0 to machine a slot. The tool diameter is not taken into account." Its a crude brute force tool.
    While not exactly what you were asking about here is a 3D way to make a "pocket" with varying bottom geometry.
    Simple 3D Mold Demo Using ViaCad & CamBam - YouTube
    Bob La Londe
    http://www.YumaBassMan.com
  1. Pocket tool paths on edges
    By Plan_B in forum Vectric
    Last Post: 11-12-2012, 09:33 AM
  2. Replies: 12
    Last Post: 05-17-2012, 03:21 AM
  3. Creating Tool paths with a solid
    By Rathi in forum Mastercam
    Last Post: 07-22-2010, 04:04 PM
  4. Creating tool paths
    By CNCMike in forum Mastercam
    Last Post: 04-15-2008, 09:38 PM
