603,960 active members*
2,541 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > K2CNC > Help with the dust hood from K2 CNC
Results 1 to 7 of 7
Hybrid View
studysession Help with the dust hood from... 05-17-2007, 03:35 PM
hindocarina Yes, contact K2 and tell them... 05-19-2007, 03:06 AM
tony784 be sure to position the dust... 06-09-2007, 05:21 AM
rrrevels stiff dust shield 06-29-2007, 06:17 PM
studysession What kind of brushes and... 06-29-2007, 06:27 PM
rrrevels I got them from McMaster... 06-29-2007, 06:43 PM
Mike Stevenson Hi studysession, what ever... 06-17-2008, 02:01 PM
    Question Help with the dust hood from K2 CNC
    When I am cutting and the router changes directions. The plastic lifts the router a bit and then the cut isnt exact. The plastic is really stiff.
    Any suggestions on what to do?
    I am using this mount for my Hitachi Router:
    http://www.k2cnc.com/shop/proddetail...Hitachi&cat=31
    And this for the dust collector:
    http://www.k2cnc.com/shop/proddetail...d%2D892&cat=31
    Please check out my CNC blog
    http://cncinside.com
    Yes, contact K2 and tell them of the problem. I got a 3925 from them just 3 months ago and it uses strip brushes around the collector base instead of plastic. The brushes are real flexible and don't cause any problem at all. Maybe they still have some of the older design left. Tell them you are very unhappy with the design and you want brushes. They won't change back if they don't get negative feedback.
    Good luck,
    Charlie
    Jan 2006
    4
    be sure to position the dust hood so the plastic touches just enough to touch the top of the material at your cutting depth. Double check to make sure your router is secured tightly, but it is true that the brushes are much more flexible.
    Jul 2003
    114
    stiff dust shield
    I don't have a K2. I am dreaming of one though. I have a home built router of the 25 x 39 size. My brushes would keep the z from being accurate on the initial cut until the unit moved horizontally and the brushes bent. I made the holes holding the brushes slotted so they can move up and down about a 1/4 inch. I haven't had any more problems since. I wonder if the same idea would work with the plastic curtain.
    Russ
    What kind of brushes and where do you get them? Thanks
    Jul 2003
    114
    I got them from McMaster Carr. I bought the brushes and holders. I believe I got the 3 inch brush size.
    They are called conveyor strip brushes.
    The part number I bought was
    brush Nylon bristles galvanized steel backing 3 feet 74405T72
    Strip brush holder anodized aluminum 3 feet 8813T12
    go to mcmaster.com type in the part number in the search and it will bring up the page with the brushes and holder.
    Russ
    Quote Originally Posted by studysession View Post
    Hi studysession, what ever happened with your K2?
  1. Soft plastic for dust hood
    By sploo in forum DIY CNC Router Table Machines
    Last Post: 01-14-2008, 05:22 PM
  2. Dust collector
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 06-30-2007, 02:45 PM
  3. Dust/Chip Control...CNC Dust Enclosures
    By Too_Many_Tools in forum DIY CNC Router Table Machines
    Last Post: 07-29-2006, 07:44 PM
  4. Dust Control
    By SPEEDRE in forum CNC Wood Router Project Log
    Last Post: 04-17-2006, 02:18 PM
  5. fadal/emc/dust
    By sdmcaptain in forum Fadal
    Last Post: 05-09-2005, 08:51 PM
