603,336 active members*
3,951 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Help Identifying an old lathe
Results 1 to 11 of 11
    Apr 2009
    Hi all, I am new to the forum and hoping for some information on an old lathe that was given to me. As a preface, I have no experience with lathes or machining in general. I am fairly proficient with automotive hobbyist type metal working (cutting, bending, welding, etc...). I picked this thing up because the price was right (free) and I have always wanted to learn some machine work skills.
    I cannot find any plates/ castings/ stampings on the machine itself, I do not have it all cleaned up yet though so I have not given up hope yet.
    If you want to see pictures a different part of the machine, let me know and I will be happy to take some.
    On the underside of the table it has "13 190" cast into it near the middle.
    The motor is a "Master" type "RA" 1/2 horse 1725 RPM
    The Transmission is a Master Speed Ranger Style #112774 Size 742Q with Const. Torque of 7.5 in-lbs.
    I am hoping to find out:
    What is it?
    Can I get parts? Specifically the bearings since it seems to have a bit of play parallel to the part.
    Any general information that might be helpful.
    Thank You.
    Josh
    Attached Thumbnails Attached Thumbnails IMG_0058.jpg   IMG_0061.jpg   IMG_0062.jpg   IMG_0063.jpg
    Jan 2006
    4396
    If I had to guess, it could be a very old LeBlond.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2008
    240
    Looking at the compound - SB
    Feb 2006
    1187
    Southbend is my guess, the belt drive pulleys looks they were added later to replace the flat belt pulleys
    Mar 2005
    1673
    Have a look here http://www.lathes.co.uk/southbend/ if its not a Southbend some digging around on the site should answer your question.
    John
    Mar 2005
    1673
    Mar 2009
    23
    JoshF
    Big No No! That chuck key in the chuck. Get you hurt fast. Seen it. Ugly when it happens. Number 1 rule in most shop, never leave a chuck key in the chuck.
    As for the lathe, check the ways back by the tail stock, just at the end of the ways, Southbend would stamp a number on the operators side, if it's a S-bend, you can date it with that serial number. What ever the mfg. it looks pre-50's. Have a 1946 S-bend with that same dial in feed levers. Love to run it!
    regard
    Paul
    Nov 2005
    1468
    Weeee ever seen a chuck key getting launched from a chuck? I have... it didn't half make a mess of the ceiling.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Oct 2005
    1237
    Saw the end result hole in the wall. 30' over the shoulder of the operator.
    Dec 2008
    3211
    Looks like the model before this one
    ( date plates end at 1910, puts yours around late 1800's)
    http://theoldmachine.com/journal/sen...2-metal-lathe/
    BTW. has the museum asked for it to be returned yet ?
    ( reminds me of the ones we had in school, all driven from an overhead main drive shaft )
    Jan 2006
    4396
    Quote Originally Posted by Superman View Post
    Seneca Falls is close to where I was born.
    Toby D.
    Schwarzwald
  1. Help Identifying This
    By WeaSiL in forum CNC Machine Related Electronics
    Last Post: 04-08-2009, 09:35 PM
  2. Help identifying materials
    By frankieboy5000 in forum Community Club House
    Last Post: 03-16-2009, 07:08 PM
  3. Need help identifying
    By pflynnjr in forum Stepper Motors / Drives
    Last Post: 04-18-2007, 05:58 PM
  4. identifying wiring
    By stearman in forum Stepper Motors / Drives
    Last Post: 04-28-2006, 07:17 PM
  5. Help identifying this please
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2004, 08:40 PM
