603,392 active members*
3,631 visitors online*
Results 1 to 7 of 7
    May 2006
    14
    Help Identifying This
    I recently found that an amplifier I have stopped working (audio amp) and since there is no warranty left I pulled it apart to have a look. There are a few items that are blown and since transistors and resistors are cheap I figured I would replace them and see if it works again. Can't hurt right.
    Long story short, I can't seem to identify who makes this component or exactly what it is and what I need to replace it. If anyone can help it would be greatly appreciated.
    Thanks,
    Scott
    //edit// It should have 3 legs, not one, the other 2 broke off when the amp blew //edit//
    Apr 2006
    187
    Check page 4, I think.
    http://www.fujisemiconductor.com/old...vplanation.pdf
    Hope it helps.
    Dec 2003
    24260
    It looks like a back to back half bridge diode pair.
    2SC2505 comes up as a transistor, you may have to google combinations of the part no.
    There is a also a similar device that Teccor call a 'Sidactor' this is a bi directional surge suppressor.
    Al.
    Albert E.
    Apr 2006
    187
    Reasonably sure it's the T-stack diode, c-type, shown in the PDF shown from earlier post, I thought it was transistor at first, but found that pdf, and diagram on bottom of pdf page 4 matched diagram on device jpg.
    May 2006
    14
    Thanks for the info. All I have to do now is try and find a digi-key part number so I can add one to my order.
    Thanks again,
    Scott
    Dec 2003
    24260
    Is the heatsink the diode centre connection?
    If so DigiKey UHB20FCT-E3/4WGI.
    If the tab is isolated, then it won't matter.
    Al.
    Albert E.
    May 2006
    14
    Yes the heatsink is the centre connection. The part you referenced looks like it will do just nicely. I am ordering a bunch of parts for the psu of my cnc mill project and will be ordering the parts I need to repair the amp at the same time.
    Thanks for all the help.
  1. Help identifying servo
    By Wolfmarsh in forum Servo Motors / Drives
    Last Post: 03-12-2009, 02:08 PM
  2. help identifying components
    By Greg McFadden in forum Fadal
    Last Post: 01-14-2008, 10:32 PM
  3. Trying to Identifying a fastener
    By Tagarus in forum Community Club House
    Last Post: 05-07-2007, 12:02 AM
  4. Need help identifying
    By pflynnjr in forum Stepper Motors / Drives
    Last Post: 04-18-2007, 05:58 PM
  5. Help identifying this please
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2004, 08:40 PM
