603,545 active members*
2,329 visitors online*
    Jun 2023
    3
    HELP NEEDED WITH 808D Advanced machine- RETROFITTING ISSUES
    I am afraid I made the blunder of a lifetime buying a machine with siemens control as the knowledge and support is absymal.....
    fitted an automatic lubricator since the machine has a manual lubricator.
    to get to the point, I want to activate the feature...
    I connected the switch of the lubricator (lub low level ) to X012 input pin 8 and Pin 10 when switched on should display lubricant Low.
    There are two other parameters involved.
    14510 (24) which controls the lubricating interval and 14510 (25) which controls the duration I have put 5 for 24 and 25 for the 25. This should make the machine lubricate its pulse every 5 minutes and for some 2.5 seconds
    However, nothing takes place when the switch is activated.
    is there some other parameter to activate this? do the time intervals have any effect? because they do not have a bearing on this..
    if someone reads this and can suggest where can this information be obtained please help.
    Many thanks in advance!
    Mar 2024
    53
    Re: HELP NEEDED WITH 808D Advanced machine- RETROFITTING ISSUES
    okk contact me at [email protected]
  1. Siemens 808D Advanced New Tool Edge problem
    By medliningmachineworks in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-01-2020, 02:11 PM
  2. Siemens 808D Advanced Control Problem
    By medliningmachineworks in forum Milling
    Last Post: 08-31-2020, 10:47 PM
  3. Replies: 3
    Last Post: 04-09-2019, 02:12 AM
