587,272 active members*
5,163 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Help required: 2D DXF to NGC in XZ plane for foam cutter
Results 1 to 4 of 4
    Jan 2011
    9
    Hello. I'm an electrical engineer with CAD and programming experience. I'm finishing a homemade 3-axis CNC machine with control by EMC2. Everything going well. I don't have a spindle yet so I've made a hot-wire foam cutter attachment. It's mounted on the Z-axis with the wire parallel to the Y-axis.
    I need some help in converting DXF to NGZ. Can members recommend -
    1. DXF to NGC conversion utility. (I can use Windows or Linux.)
    2. Explain how I specify that the cut path is in the XZ plane.
    Many thanks.
    Jan 2007
    146
    Cambam has a Free version and several good tutorials to get you started. His price was very reasonable for the full version.
    linux has gcam, pycam, and a gcode hack for blender. I have not enough patience to learn to use.
    Jan 2007
    148
    Also take a look at Heekscnc & Heekscad
    heekscnc - CNC machining add-in for HeeksCAD - Google Project Hosting
    orentation of the axis is in the configuration
    also a good program for foam cutting is
    http://gm.cnc.free.fr/en/index.html
    and Jedicut
    http://www.aeropassion.net/index-en.php
    Jan 2011
    9
    There's some fantastic stuff available. Thank you all for the links and your time and trouble.
  1. Foam cutter Kit
    By RedLabel in forum CNC Wire Foam Cutter Machines
    Last Post: 11-06-2012, 05:43 AM
  2. Info Required For Acrylic Cutter
    By Bread_O in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-01-2011, 12:39 PM
  3. Hot Pin Foam Cutter
    By damae in forum CNC Wire Foam Cutter Machines
    Last Post: 01-25-2009, 02:40 AM
  4. Cutting bed is out of plane with the cutter
    By hualon in forum DIY CNC Router Table Machines
    Last Post: 06-22-2008, 05:28 PM
  5. My first CNC! soon to be foam cutter
    By nikolatesla20 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-06-2005, 07:48 PM
