603,790 active members*
2,767 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help with some Gcode on fanuc Om ...Please :)
Results 1 to 8 of 8
    Mar 2004
    185
    Hi All,
    need some help
    Just trying to work out how program some Gcode on my fanuc OM VMC with a high speed spindle that attaches to the BT40 tool holder and powered independently.
    Basically i don't want the main spindle to start for obvious reasons.
    I have tried inserting S0 M3 abd doesnt like that. The code stops at that line.
    I have also tried taking that code out and it didnt like that either ...
    Any other ways to do this ?????
    Heres a sample code im using ......
    Thanks in advanced
    :1248
    N20G91G28Z0
    N30G40G17G80G49
    N40T24
    N50G90G54
    N60G43Z20.000H24
    N70G0X0.000Y0.000S0M3
    N80G0X-0.009Y-0.103Z6.000
    N90G1Z-0.010F110.0
    N100G1Y49.897F900.0
    N110X80.871
    N120Y-0.103
    N130X-0.009
    N140G0Z6.000
    N150G28G91Z0
    N160G49H0
    N180M30
    Apr 2019
    141
    Re: Help with some Gcode on fanuc Om ...Please :)
    Here´s a response in the German forum:
    https://de.industryarena.com/fanuc/f...m--100744.html
    Translated by deepl.com:
    Hello Jubee,
    not quite sure if I have understood your problem.
    Would suggest:
    Either work with spindle orientation M19 or activate spindle clamping. I think ours was M86 and M87.
    Hope that helps.
    MfG
    unaware
    Community Manager <a href="https://de.industryarena.com/" target="_blank">https://de.industryarena.com/</a>
    Dec 2008
    3214
    What happens if you omit the S0 M3 from the program ?
    Or
    Use M5 or M19 instead of M3
    Note... you should be using feed per minute (G94), not feed per rev (G95)
    An observation of tour code....line 30 should include G90 and G94, as these are usually the default codes for each group
    And a general practice of "if you switch sometime away from default, make sure it gets turned back ASAP", I'm talking about your use of G91 (incremental), N155 G90 is a suggested, as the machine is left in absolute
    Mar 2004
    185
    Thanks guys for your replies, Will do some more testing today and post later of my findings.
    I really appreciate having a look at the code as well, I need all the help i can get . Thank you
    Mar 2004
    185
    Hi Burs, thanks for that.
    It doesn't need to lock just needs to not turn. So no spindle rpm at all.
    The code I've tried ie leaving out the M03 and S , doesn't seem work. But will try a few more things today.
    Thanks for your input though
    Mar 2004
    185
    More testing today , and i couldnt get it to work .....
    Works up until the command to move the x and y axis. Then nothing.
    I have read from another website that i may have to enable one of the Parameters?
    Does anyone know how to change Fanuc parameter 24.2 = 1
    From what i have read that this will stop the controller looking for spindle speed prior to x and y axis moving.
    Any thoughts ????
    anyone
    Mar 2004
    185
    From the parameters manual it looks like Parameter #24 bit 2 =1 is checking the spindle speed is reached.
    Will try changing this tomorrow and see what happens
    Mar 2004
    185
    Well it worked., those of you following
    Changed Parameter 24, BIT 2 to a 0 and all is good the machine doesn't look at the spindle status before it executes the X and Y moves.
    Happy days.
    This is what the high speed spindle looks like ......45000 RPM 220 volt Click image for larger version.
  1. Dxf to Fan conversion or gcode laser GE Fanuc 0mc controller.
    By LASERMAN47150 in forum Uncategorised CAM Discussion
    Last Post: 05-14-2024, 03:16 PM
  2. Fanuc 0M Gcode file size?
    By NitroCH3NO2 in forum Fanuc
    Last Post: 08-30-2020, 07:42 PM
  3. newbie Q regarding fanuc 0T lathe Gcode
    By cnc1921 in forum G-Code Programing
    Last Post: 06-10-2017, 04:23 AM
  4. Replies: 3
    Last Post: 12-22-2010, 07:57 AM
  5. FANUC GCode from SolidCAM
    By Jixxer in forum G-Code Programing
    Last Post: 09-04-2009, 07:52 AM
