587,827 active members*
2,974 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Hi all, Tool diameter offset question.
    Sep 2005
    28
    Hi, I have been teaching myself how to use a friends VF3 and have some questions about tool diameter offsets.
    I was doing a test piece for a bearing seat. I am using the tool probe to set the length and diameter and this seems to be working because things are turning out exactly as designed. Now my question is how can I fudge the tool offset by .0005 to give me a little room for the bearing.
    I have tried to add and subtract up to .004 from the diameter of the measured value with no difference in the cut. I have also tried the same with the wear and still can't get it to fine tune my hole.
    Now I understand that I should just program it a little bigger but some times it is not as easy as just bumping the tool diameter a smige and re running the hole for a smooth fit.
    Any suggestions?
    thanks,
    Chad
    Mar 2003
    2932
    If you put a G41 Dnn or G42 Dnn in your program, the subsequent moves will be compensated left or right by the value stored in Dnn. Since I don't know what your program looks like... imagine milling a 2.000 circle centered at X0, Y0 with a 1.000 diameter end mill, and D01 set to 0.000.
    Measure the bore after the 1st run. If it's undersize, put a - (minus) comp value in D01.
    O0100 (INTERPOLATE 2.0 DIA W/ 1.0 EM)
    N005 T01 M06
    N010 G00 G54 X0 Y0 S2500 M03
    N015 G43 Z0.1 H01
    N020 G01 Z-0.5 F20.0 M08
    N025 G41 X0.5 D01 F5.0
    N030 G03 I-0.5
    N035 G01 G40 X0
    N040 G00 Z0.1 M09
    N045 G53 Y0 Z0
    N050 M30
    Sep 2005
    28
    Ok, that helps. I will play with that.
    Thanks.
    Chad
  1. Changing tool diameter in the tool offset screen
    By Vern Smith in forum Haas Mills
    Last Post: 05-09-2022, 05:25 PM
  2. tool offset question
    By WarrenW in forum SheetCam
    Last Post: 04-29-2006, 07:43 AM
  3. question about Yasnac tool offset in the Z
    By DDuley in forum DNC Problems and Solutions
    Last Post: 02-19-2006, 02:23 AM
  4. G43 Tool Offset question
    By sbrunton in forum LinuxCNC (formerly EMC2)
    Last Post: 07-21-2005, 04:53 AM
  5. Any Info On Tool Diameter Compensation?
    By FLUTE HEAD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-26-2004, 11:02 PM
