588,159 active members*
4,991 visitors online*
IndustryArena Forum > CAM Software > Mastercam > holding tabs in X3
Results 1 to 5 of 5
    Sep 2007
    300
    holding tabs in X3
    I recall reading x3 has the feature to leave small holding tabs on parts so they stay in place and do not move around when cut away from the stock.
    I have yet to find this in the software. Can someone direct me to the feature and what it is called? Any pointers on its use would be helpfull also.
    May 2008
    666
    Just go to the help section in Mastercam, goto search section, enter TAB in the search field and you have a pretty detailled section about it.
    Sep 2007
    300
    wow, that was fast service! Thanks much!
    I guess I have wandered by it and not even realized it in the past. Never had a need for it until recently.
    Jan 2008
    123
    Contour toolpath lower right corner...Tabs button
    If you are cutting through the part don't forget to figure the break through into the tab thickness if your part is .250 thick and you set up to cut through .280 and you want a .100 thick tab put .130 in the tab value...it references off the bottom cut
    May 2007
    71
    thanks
  1. Retaining tabs
    By ssozonoff in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-05-2009, 10:43 AM
  2. Tabs How and Where?
    By Mr.Chips in forum Uncategorised CAM Discussion
    Last Post: 03-04-2008, 03:08 PM
  3. G-Code for holding tabs
    By mikemill in forum Uncategorised CAM Discussion
    Last Post: 06-05-2007, 12:38 PM
  4. Problem using tabs
    By LongRat in forum SheetCam
    Last Post: 08-06-2006, 09:39 AM
  5. Tabs in V9
    By MikeA in forum Mastercam
    Last Post: 03-21-2004, 12:55 AM
