Here's the new G0704 MAD V2.
The first video is the construction and the 2nd is the operation.
The aluminum cross member does have a little bit of flex, maybe .010, but doesn't affect the operation.
I made mine using (2) 1/4-20 screws into the cross member but that seems a little too big
so I spec (2) 10-24 in the print to leave more meat in the side brackets.
One note about this mill since this was my first real use of it to make something, I LOVE IT.
It's the perfect size for sitting there running it, can get up close and personal.
The smoothness of the axis' and the rigid cutting make it a joy to use.
The noise of my gear change wasn't too bad at the lower rpm, could still hear my tunes.
One simple thing I would do if I was going to keep it manual would be to add some longer dial marks
for .005 and .010 so my old eyes could see better.
I like doing things manually, so going CNC will be hard, but I will.
One note about the bearings, even cheapo replacement TRs for the upper bearing that takes
the load from the tool change have static load ratings over 7000 lbf,
750 lbf from the tool changes is nothing to fret about, at least not to me.
The cutting in the first video shows it taking .200 DOC with .375 4 Fl HSS 1100 rpm
about 4-5 IPM, works out to a .001 chip load. Piece of cake.
First pic shows a poor mans dykem.
Hoss
video embedding seems on the fritz
[nomedia="http://www.youtube.com/watch?v=s8nbImWDnLg"]YouTube- G0704 MAD V2 Construction[/nomedia]
[nomedia="http://www.youtube.com/watch?v=86fWHkJiuSM"]YouTube- G0704 MAD V2 Operation[/nomedia]
