603,988 active members*
3,157 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How can I avoid Foaming in my cutting fluid tank? (attached drawing for reference)
    Jun 2019
    5
    I've connected an eductor to the coolant pump in my machine. This eductor sucks the leaked cutting fluid from a tray underneath the machine I.e coolant passes through the venturi(let's call it motive) and returns to the tank and in this process a vacuum is developed which is used to suck up the oil from the tray which travels with the motive and enters my tank.
    Now the problem I'm facing here is once all the leakage oil has been sucked up the device keeps sucking air which is then transferred into the coolant sump thereby causing a lot of foam.
    How can I prevent air from entering the tank? I cannot use any timers or solenoids to turn off the system. Need a simple mechanical suggestion please. Can't add any Calcium or any other defoamer either.
    We have tried to keep the return pipe submerged under the coolant level and kept it over the coolant level to see if either helped, but both situations created foam. Concentration & water softness is high, and the client is adamant on maintaining the existing parameters due to the surface finish requirements.
    Please see a schematic of how the system is working right now : https://i.imgur.com/nZbOKG1l.jpg
    Any help will be appreciated. Thanks.
    Apr 2004
    5951
    Re: How can I avoid Foaming in my cutting fluid tank? (attached drawing for reference
    Normally, sump pumps are equipped with a float switch - could that work here?
    Andrew Werby
    Website
  1. What cutting fluid do you use?
    By nateman_doo in forum Benchtop Machines
    Last Post: 02-10-2012, 08:37 PM
  2. RFQ: Mill work for small alumium pieces. Drawing attached.
    By Siubee in forum Employment Opportunity
    Last Post: 05-17-2010, 08:47 PM
  3. Cutting fluid
    By sleeper142 in forum Haas Mills
    Last Post: 07-29-2007, 02:05 PM
  4. Is my drawing ok? *file now attached*
    By Zamm in forum Musical Instrument Design and Construction
    Last Post: 06-26-2007, 10:17 PM
  5. Newbie question: how do I machine this? (Drawing attached)
    By Aegeon in forum MetalWork Discussion
    Last Post: 12-04-2005, 08:20 PM
