I defined the area for the chamfer and arc with contours,then in the cam program I use the Z profile function to create the tool paths. The parameters and tooling can be tweaked, if you double click the operation name listed on the left the fuction will reopen. You can also go back to the cad program and edit profiles and contours, remember to save.
