587,986 active members*
4,704 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > How do I change autofeed direction?
Results 1 to 4 of 4
    Feb 2004
    157
    How do I change autofeed direction on my Harbor freight model BV-920 lathe? It feeds into the headstock, not away from it. It will feed away from the head stock if I change the motor direction but then the spindle spins reverse as well. Is it ok to cut with the spindle spinning the wrong way? Is there a way to make it auto feed away from the headstock and still have the spindle rotate toward me?
    (I'm relativly new to machining, only had one class back in college)
    thanks.
    www.bigbearcnc.com
    Apr 2005
    1778
    Mike,
    You have to add an idler gear in the gear chain. That wil reverse the direction of the leadscrew relative to the rotation of the spindle.
    Alan
    Feb 2007
    424
    Its often refered to as the LH or left hand threading mod.
    surf the web there are several good sites, don't limit the views of other lathes as they all pretty much work the same way 9x20 7x10 etc.
    chris
    Feb 2005
    149
    well the 7x10 lathe actually is easy, all you have to do is flip the directional feed bar on theback of the lathe to change feed towards or away from the chuck. You can spin the chuck clockwise or counter clockwise as well. They already have that feature built into the lathe so no mods are required...not sure about the 9x20 though, my other lathe is the grizzly 11x26
    Dan
  1. EMC2 - Step/Direction Change Precharge
    By NightHawk.Eng in forum LinuxCNC (formerly EMC2)
    Last Post: 08-13-2007, 07:30 PM
  2. Replies: 2
    Last Post: 02-27-2007, 05:46 PM
  3. A axis direction change?
    By nervis1 in forum Fadal
    Last Post: 10-27-2006, 04:49 PM
  4. HOW:Line Direction change for MANY lines
    By rherman in forum BobCad-Cam
    Last Post: 09-20-2006, 09:43 PM
  5. How cutting direction change
    By freesman in forum BobCad-Cam
    Last Post: 07-28-2006, 09:02 PM
