603,939 active members*
3,719 visitors online*
Results 1 to 4 of 4
    Jul 2009
    8
    How do I change tools?
    I'm a newbie and have a Dyna cnc router with zip for documents. I've been watching the Artsoft videos and they are amazing. I have run a few test files and stuff seems to be working ok. A couple of questions though...the Mach 3 program that has my machine profile set up is not the same one in the tutorials. I do not have a tool selection box. I found the toolbox table and wrote in diameters and lengths of router bits but for the life of me cannot find a way to select that tool. It always says Tool 0 up in the corner of my black box. I do have on the same computer Mach 3 Mill. This one looks like the tutorials but has not been configured at all. Both programs are version 1.83.005 Any tips? Thanks in advance
    Mar 2003
    35494
    In your g-code, M6 T1 will change it to tool 1. If you want to use Length Offsets, then use G43. See thw manual on how to use it.
    That's a pretty old version of Mach3, and I'm not sure if the following still holds true for your version. If you want to change tools in a program, you call M6 Tx. In Mach's cofiguration screen (Config>General Config), you can set a few different options for what Mach3 will do when it sees an M6.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2009
    8
    So should I ditch this version and get the latest?
    Mar 2003
    35494
    Unless you're having problems, or need a feature that only a newer version has, I'd say no.
    Gerry
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. Mini-CNC machine tools and CNC machine tools-ray machine
    By aiven.xie in forum News Announcements
    Last Post: 09-24-2012, 07:53 AM
  3. Bring your own tools or does your company supply tools?
    By ZipSnipe in forum Community Club House
    Last Post: 02-05-2011, 02:06 AM
  4. Leadwell MCV-OP do not change Tools
    By uli kolb in forum Uncategorised MetalWorking Machines
    Last Post: 08-14-2008, 04:00 PM
  5. Possible to change tools while XY rapid??
    By little bubba in forum Fadal
    Last Post: 12-01-2005, 03:08 PM
