588,344 active members*
5,096 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > How to link CamBam to machine?
Results 1 to 6 of 6
    My company is in desperate need of some CAM software and cambam will suit all our needs, i have trial version but dont have a clue where to start linking it to machine.
    Help would be MUCH appreciated!
    Thanks,
    Jack
    Oct 2005
    124
    Re: How to link CamBam to machine?
    I think Cambam is only CAD/CAM software. You can draw a part and create the gCode but you'll need controller software to actually run the code on your machine. Lost of people use Mach3 for controller.
    Gary Shepherd
    www.16tracks.com
    We have a Bridgeport Series 2 MDI with heidenhain tnc 145. I am aware people have linked cambam with tnc 151 i just dont have a clue where to start!
    Jun 2006
    3063
    I've not used CamBam, but generally you tell your CAM software to use a postprocessor to convert the machining operations you create into G-Code commands that the machine controller would understand. CamBam is supposed to have very good tech support, so you might try contacting them and see what they suggest.
    Mike
    thanks mike i will give them a ring!
    Aug 2014
    125
    You need to load the Heidenhain server software on your PC and then CamBam interacts with that and controls the machine.
    good info, including downloads, on the Cambam forum: Heidenhain TNC151 Conversational
  1. Replies: 2
    Last Post: 10-26-2010, 01:55 AM
  2. Link to Haas' Tony Stewart machine
    By HAILINHAAS in forum Haas Mills
    Last Post: 06-20-2009, 09:08 PM
  3. How to link CATIA to a CNC machine
    By LFB in forum CNC Wire Foam Cutter Machines
    Last Post: 02-26-2009, 03:11 PM
  4. MACHINE LINK DNC to TPLUS
    By TRANSATOOL in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-09-2008, 07:10 PM
  5. Will CAMBAM run in Win 98 ?
    By epineh in forum CamBam
    Last Post: 08-03-2007, 06:50 AM
