603,365 active members*
2,988 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > How to setup basic parameter settings for any vfd
    Jun 2014
    Lightbulb How to setup basic parameter settings for any vfd
    Since the presence of various Chinese or cheap VFDs, It is really difficult to find out the basic parameter settings for each of those. There are lot of differences between these VFD settings.Specially the program number or else p modes and there functions varies from one VFD to another.
    So instead of being fool by changing values,Do it like this for your ease. Most of the VFDs have detailed manual describing the functions of there pmodes. So take the manual and find the related pmode number according to the description below.
    Function Description Value
    Parameter lock/unlock 0
    Start signal selection 0
    Max. frequency 400
    Min. frequency 20
    Acceleration 12
    Deceleration 12
    Max. voltage 220
    Base/Intermediate frequency 400
    Intermediate voltage 15
    Min. voltage 8
    Spindle/Motor rated voltage 220
    Spindle/Motor rated current 6
    Spindle/Motor RPM 3000
    No of motor poles 2
    For an example pmode for Acceleration in my VFD is P107 but in Huanyang Mactec54 it was PD014
    So these are the basic settings need to be done. You can check the function description in your manual and find the correct pmode number and change the value as given.
    Bingo I hope now you all will be able to setup any VFD without any hassle.
    Thanks for this great thread that inspire me to do this.
    http://www.cnczone.com/forums/spindl...gs-manual.html
    I would appreciate any comments.
    Jan 2005
    15362
    Re: How to setup basic parameter settings for any vfd
    djnuwa
    No matter what Chinese 400Hz spindle you have, you would never have a Min. frequency Parameter setting of ( 20 )
    They can not safely run at 20Hz, the Min Frequency on most of these Spindles is 100Hz, play it extra safe & set to 120Hz for your Min Frequency
    A good quality VFD you can use 100Hz safely
    Mactec54
    Dec 2003
    24260
    Quote Originally Posted by djnuwa View Post
    You essentially forgot to qualify a particular motor, I assume you have the common W.C. 2 pole H.S. motor?
    For e.g. I am using a Huanyang with a standard 4 pole 1485 rpm motor and I can operate down to a few RPM.
    Every VFD/Motor combo is different, and many of the higher end VFD's have an auto tune to get you in the ball park.
    Al.
    Albert E.
  1. NM-200 VFD parameter settings
    By nelson_nm200 in forum Novakon
    Last Post: 06-08-2012, 04:42 AM
  2. Parameter Settings
    By richmond1992 in forum Drilling- and Milling Machines
    Last Post: 11-15-2011, 04:42 PM
  3. CNC Basic settings for LimitnSwitches
    By Keith1 in forum Waterjet General Topics
    Last Post: 11-10-2010, 12:39 AM
  4. TOOL settings, basic questions - parameters
    By expart in forum BobCad-Cam
    Last Post: 08-30-2010, 12:53 PM
  5. Basic Aluminium TIG settings?
    By Normsthename in forum Welding Brazing Soldering Sealing
    Last Post: 03-20-2008, 05:32 PM
