603,923 active members*
3,306 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > How to use the .bmp Import on DCad
Results 1 to 7 of 7
    Apr 2008
    10
    Can anyone clear up as to how to use the bitmap import on Dcam? i tried it, and it recognizes bitmaps, let me select one, and seems to have imported it, prompts for a starting point for the bmp, but it doesn't show up in the drawing. if i try to import again, it gives an error message stating that it has already been imported.
    alternately, has anyone found a good freeware program which translates line drawn picture files into .dxf?
    thanks,
    Mike
    Dec 2003
    259
    Can't help with the bitmap thing in Dolphin as I have never used it but Inkscape is a good free convertor.
    John S.
    Apr 2007
    230
    File: Import Bitmap: Pick the bmp. you want then click the cactus icon in the tool bar and your picture should appear. Then you can postion it with the mouse. Scale by zooming in or out before placement, this is a wierd feature I just discovered while writing this post.
    Dec 2007
    496
    Sqatch I have done that and it seems pretty cool. How do I get it to the cam now?
    Apr 2007
    230
    What I do is trace the lines I want with the regular drawing tools keeping in mind how you want it cut.Then create contours from those lines. The bmp. can now be deleted.Open machine modual and create tool paths.
    Apr 2008
    10
    thanks for the tip. i guess that only solves half of my problem though. i need to get up to speed with the Dcad sketcher to become efficient at tracing.
    for JohnS using inkscape, i installed it, and figured out how to trace bmp's but the .dxf export function doesn't export usable dxf's. i installed pstoEdit, as the help file for inkscape says. it got rid of the errors that popped up in inkscape when saving to dxf, but the dxf still isn't usable.
    i guess the bigger task i'm trying to accomplish is to translate a line drawing to a tool path for engraving. how have other users accomplished this?
    thanks,
    Mike
    Apr 2007
    230
    I used to use a program that had a trace command but it gave me such a mess of lines that had to be edited I found it faster to just draw them manually. You can use layers on complicated drawings to avoid confusion. After a while you get pretty good.
  1. DCad post problem: Server busy?
    By metalworkz in forum Dolphin CAD/CAM
    Last Post: 05-24-2008, 01:54 AM
  2. Z Axis Starting Point in DCAD Execute/Simulation
    By jim_stoll in forum Dolphin CAD/CAM
    Last Post: 09-16-2007, 08:08 AM
  3. DXF Import on EZ-Plus
    By md63825 in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2007, 03:32 PM
  4. import DXF
    By qmas99 in forum FeatureCAM CAD/CAM
    Last Post: 07-19-2006, 01:08 PM
  5. DXF Import
    By Todd Price in forum Rhino 3D
    Last Post: 06-07-2004, 06:24 PM
