603,383 active members*
3,583 visitors online*
Results 1 to 11 of 11
    Jun 2007
    31
    How to use drill bits
    Hello All-
    Question for you... I was using my cnc machine to cut some parts and needed to drill some small diameter holes.
    I have a Hitachi M12VC router with a 1/4 and a 1/2 inch collet.
    How would one use the router to hold small drill bits? I've looked for drill bit sets that all have the same diameter shank, but haven't had much luck.
    Any ideas?
    Thank you-
    Brad
    Mar 2003
    35494
    Quote Originally Posted by bradtal View Post
    You don't.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2007
    31
    Really?
    You don't.
    Well, that wasn't the answer I was hoping for. So all these people on this cnczone.com have or have made cnc machines that can't drill a hole? I find that odd. Why does my cam software have a "drill" function?
    For example, I found something like this online:
    http://tinyurl.com/8wh9lp
    I wouldn't want to chuck the shaft into my router collet, but do they make something like it that you could chuck into a router collet?
    Brad
    Mar 2006
    474
    How big of a drill chuck do you want to turn? Have a taper ground on a piece of round stock to fit your router and the chuck of your choice, and hold it like a router bit.
    Or, you could get one of the hand-drilling attachments, or "Micro Drill Adapters" ( http://www1.mscdirect.com/CGI/NNPDFF...0&PMT4TP=*LTIP ) with a micro chuck on it, and take it apart.
    The inner, sliding shaft is .250" diameter, and hollow, about 2" long.
    Mar 2003
    35494
    For one thing, it's not really safe to spin standard drill bits at 10,000 rpm plus.
    One option, is to get a Porter Cable router, and buy a 1/8" collet from http://www.precisebits.com/
    Then you can get small 1/8" shank drill bits that are made to spin that fast.
    http://www.precisebits.com/products/...sPT=fractional
    Gerry
    Jun 2007
    31
    Ok.
    Gerry-
    Thanks. I think you answered my question. I actually have those bits already and I have a router that has a 1/8" collet. I was just hoping not to have to switch out my new router for the old one when I need to drill holes.
    Thanks for the help and the links.
    Brad
    Mar 2003
    35494
    You can always buy a 1/4" to 1/8" adapter. As long as it doesn't have much runout, it should work OK
    Gerry
    Jul 2007
    265
    http://www.precisebits.com/default.htm sell adapters. Click under where it says "The Bushings are Here!"
    Mar 2003
    35494
    Quote Originally Posted by tahustvedt View Post
    Right below that it says "Not Sold Separately". They come pre-mounted on the bits for $3 extra. At least that's how I'm reading it.
    Gerry
    Sep 2006
    245
    I just use spiral upcut router bits. They seem to drill just fine. Downcut bits might not work so good.
    Steve
    Jul 2007
    265
    Oops, sorry about that.
  1. Tap & Drill Bits - Help Please
    By CheekieMonkies in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-04-2008, 02:11 AM
  2. Keep breaking drill bits
    By Chris64 in forum MetalWork Discussion
    Last Post: 03-28-2008, 04:23 PM
  3. EGX-20 drill bits
    By Richie_EGX in forum Engraving Machines
    Last Post: 05-10-2007, 06:17 PM
  4. Have you ever seen these drill bits?
    By yohinan in forum MetalWork Discussion
    Last Post: 02-06-2007, 05:21 AM
  5. Drill Bits
    By dighsx in forum Community Club House
    Last Post: 01-24-2007, 08:06 AM
