603,341 active members*
5,704 visitors online*
Results 1 to 4 of 4
    Aug 2007
    32
    HSK 63 Tool Holder Stuck
    Hi Guys,
    I have a Fimec ES929 HSK 63 spindle with less than 100 hours use which I allowed to bottom out on some MDF for a couple of minutes.
    When I removed the slightly discoloured tool holder and cleaned it up there was a bit of greasy residue in the bottom the tool holder cavity which I hadn't noticed before
    I tried to clean out and cool the lower end of the spindle- yeah I know now a dumb- to ensure the bearings were OK.
    Since then I have inserted another tool only to have it seize up in the Spindle nose.
    So far not wanting to damage anything with the knochrometer I have dismantled as much of spindle as I can but still can't dislodge the tool holder
    Any suggestions would be greatly appreciated in an effort to remove the Tool holder and prevent any furthe issues .
    Pete
    Mar 2003
    35494
    Re: HSK 63 Tool Holder Stuck
    Are you sure it's not being held by the grippers?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2007
    32
    Yes my first problem is getting the gripper to release
    Aug 2007
    32
    Update that might hopefully help some one else who might find themselves in a similar situation.
    I was reluctant to use a hydraulic press when I was unsure of the components and did not have an exploded view of them so I just built a simple press from steel tube and threaded rod which enabled me to gently apply pressure to the assembly . With this I was able get the top and centre section of the shaft to move down and open the gripper assembly but the tool holder would not release so I drilled a couple of access holes in the collar to allow symmetrical leverage on the tool holder which eventually popped off.
    Once removed I was able to remove the centre section of the gripper with a 4 mm Allen Key and the thoroughly clean the area with acetone. I suspect that I could most likely have achieved the same result if I had just inserted the 4 mm Allen key through the centre hole in the tool holder in the first place and allowed it to come out without the need to disassemble the spindle at all!
    Peter
  1. Stuck tool holder
    By maxine in forum Haas Mills
    Last Post: 02-06-2014, 08:56 PM
  2. tool holder geting stuck in spindal
    By skippyfix in forum MetalWork Discussion
    Last Post: 07-12-2009, 01:39 AM
  3. tool holder stuck in spindle
    By samu in forum Bridgeport / Hardinge Mills
    Last Post: 07-11-2009, 07:16 AM
  4. tool holder stuck in spindle
    By Runner4404spd in forum Fadal
    Last Post: 03-02-2009, 03:24 PM
  5. ER-16 Collet stuck in ER-16 Tool Holder
    By JWB_Machining in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2008, 08:04 PM
