![Quote](images/misc/quote_icon.png)
Originally Posted by
strikermed
FIX FOR ARC FAULT: So my bottom line problem was anytime my hyuang vfd was powered up whether it was on an arc fault circuit or just a GFCI circuit, I would have some kind of trip. When it was on the Arc Fault, when I powered the spindle it would trip... When it was on the GFCI, and I just had the VFD powered on, but I attempted to trun on a device, say my dust collector or table saw, which reliably have been on arc faults for over a year, those arc fault breakers would now trip when trying to power them up...
I've been doing a lot of research and tried out a 20amp run of the mill EMI filter form amazon. It takes a ground, hot, and neutral. Luckily I didn't try installing this, but just installed it with some jumpers, because it would have been a waste of time. That did not fix the problem like so many have said would help.
The reason for considering an EMI filter is because the VFD puts out a lot of EMI and RFI, and it tricks the arc fault into tripping. To find out more about arc faults go google it, there is a lot of information on how they work out there, and it's quite interesting.
The solution I found. First a quick story: I was walking through costco, and decided to take a look at those battery backups (I use them on all my computer and server gear.) I knew they conditioned power, and I didn't know if that meant that they just provide a reliable voltage, or if it does anymore. What I discovered on the box was an EMI filter.... That's made a light bulb go off. I bought the cheap $50 version and brought it home. I plugged the guy in, USED THE SURGE side of the unit and Wamo! Perfect, everything functioned as it should. This made me think, well I could try reverting the breaker back to arc fault. I did the quick change, and Yatzee! Everything still worked.
A few words of caution with this, and it's information that Myrtec has mentioned as well.
This is not a solution for everyone. I wish I knew what kind of EMI filters they used in the Cyber Power units, because it would be nice just to include a 20amp version in my control unit. I've done thorough testing on amperage and voltage of my unit starting up, underload, and every scenario I can think of, and I haven't peaked over 4.6 amps, and I haven't see more than 360 watts. Thus my machine is small. I have 110V system, with what is claimed to be a 2.2K spindle. It can go up to 24000RPM, and the spindle is rated at 8amp. In this scenario, I have plenty of headroom to plug this unit into the power surge side of this unit. I would not suggest plugging into the battery because you could potentially do damage to it.
This answered all my problems. I wish I could have a filter inside the case that could work, and I may still look for one, but the one I used had these ratings so you are aware of what didn't work:
L:4x0.5mH, CX:3x0.1 uF, R:1M ohms, CY2x3300pF It's a 115/250V~20A 50/60Hz unit model JRW1220-22 Jin Rong Brand. This unit did NOT work, so if someone has another unit that does work for this please list it below.
As for a higher power spindle, mine cuts what I'm trying to cut right now... If I find I can't cut something, I'll consider upgrading to a 220V option down the road for more torque.
