603,853 active members*
3,687 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai Hit 8S corrupt drive segment
Results 1 to 8 of 8
    Feb 2019
    3
    Hi all,
    I'm new to the forum, and I hope to find a solution for my current problem.
    I'm from The Netherlands and use my (fairly old) CNC machines for prototyping and hobby.
    Last year I bought a Hyundai Hit 8S lathe with my brother, we bought it with a defect to the hard drive with the intention to fix it.
    we were told it would not boot anymore, so we thought the complete drive had a defect. we pulled it out of the machine to see if it would run.
    connected the power supply to make sure the disc would rotate freely and did not had a physical crash. this was not the case so the hardware should be intact.
    second step was to connect to a pc to confirm if the communication was still working properly, this did not work sadly enough.
    after some searching we found out the drives have a separate power supply for the logic part of the drive, when we established to connect this we could see the drive on the pc but where not able to enter it.
    we bought a second hand drive in the US so we could swap the logic board and see if this was the problem, stil no luck.
    luckily our father does not like to throw away old equipment and we had a running 486 to connect our drive to.
    this took us a little further and we could see the drive's memory, no problems there in terms of size. but there ended our options because it still wasn't accessible.
    We contacted a recovery lab to see what they could achieve, our hope was that the PLC an machine data could be saved from the drive.
    they tried several options but could not get op to the point we reached with our 486, the proposed to send it to a cleanroom lab to physically remove the disc to get a readout.
    It took a while for them to figure out they could not enter the drive due to a corrupt drive segment.... Bad luck!
    Our only two options are to get a drive image from a Hit 8S or a similar machine 15S or 18S and load in our machine parameters which we have on paper.
    our we could contact Siemens o fix it but that is our last resort.
    Is there anyone who could help us get an image or knows somebody who has a drive backup that is willing to send us this (payment is of course not a problem)?
    Our is there a known company who sells this data?
    The controller is a Sinumeric 840C
    the pc runs on ds dos (not ms dos)
    Your help is much appreciated!
    Regards,
    Coppe
    Feb 2019
    Re: Hyundai Hit 8S corrupt drive segment
    I have a Hyundai HIT 18s I have all the files and directions how to install the images back on the hard drive on a disk. I think this will help you it has the pclink also you have to install it through dos.
    Feb 2019
    3
    Quote Originally Posted by 1cox2mac View Post
    Hi 1cox2mac, That is awesome, how can we arrange this and do you want a payment for this data?
    Feb 2019
    3
    Hi 1cox2mac, could you activate your private messaging?
    Regards,
    Coppe
    Feb 2019
    Quote Originally Posted by Coppe View Post
    Regards,
    Coppe
    Email me I haven’t figured all this out sorry 1cox2mac.sc@gmail.com
    May 2015
    I have clone of the hard drive for an 18S. However, I have no further experience resurrecting/replacing an 840C.
    Feb 2025
    Quote Originally Posted by zsh View Post
    Hi I'm new to this site I was wondering if you still have a clone of the hard drive seeing as I have one of these machines and having the same issue with my machine I would greatly appreciate it.
  1. Hyundai HiT-18s Siemens hard drive replacement
    By svtford4x4 in forum Hyundai Kia
    Last Post: 03-29-2020, 05:14 AM
  2. segment to short
    By klm123 in forum CamSoft Products
    Last Post: 12-25-2014, 11:50 AM
  3. Bad segment number
    By M Todd in forum Community Club House
    Last Post: 06-17-2013, 05:47 PM
  4. Sinumeric 840D - 7 segment LED
    By Cleverel in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-25-2009, 12:45 PM
  5. 16F84 7 segment display
    By Razer in forum PIC Programing / Design
    Last Post: 06-10-2009, 05:27 PM
