587,657 active members*
5,389 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > I need to disable the 4 axis - Fanuc 21-mb
Results 1 to 7 of 7
    Exclamation I need to disable the 4 axis - Fanuc 21-mb
    Hello, I have a Fanuc 21-mb machine and I need to disable the 4th axis - (A)
    I already tried to change the parameter 9900 - the machine does not allow to change, asks to restart it, does anyone know how to solve this problem?
    sorry for the translation, I'm from Brazil and there is no good forum like this one
    Aug 2019
    145
    Re: I need to disable the 4 axis - Fanuc 21-mb
    I think setting parameter 12.7 and 1005.7 to 1 for the A axis will do what you want.
    I did this procedure, the parameter 1005.7 was already set to 1 and 12.7 was not, when I do this, the alarm 401 appears - servo alarm : z axis vrdy off
    Quote Originally Posted by oetkbyentc View Post
    Aug 2019
    145
    Are the Z and A axis on a common / dual axis drive?
    If they are what is the drive part number?
    There may be another parameter involved in case of dual drive.
    Oct 2018
    7
    Hi all,
    I'm facing a 4th axis alarm issue, but since we don't use this axis, I need to get the machine up and running. Could anyone please advise me on how to disable it?
    Thank you.
    Oct 2005
    89
    Hello a_v_c
    PN 1010 controls the No. of axis Controlled by CNC. So if you need to Disable 4th Axis , put ( Existing Value - 1) in this Para.
    If you need to Disable any axis in Between you need to modify PN 1010 / 1020 / 1023 accordingly.
    hope it helps
  1. How to disable the Windows on Fanuc 160is
    By Namnp2007 in forum Fanuc
    Last Post: 12-01-2022, 12:17 PM
  2. Fanuc 6 TB G28 disable parameter ?
    By Shottie_gp in forum Fanuc
    Last Post: 07-22-2015, 09:36 PM
  3. Axis disable in fanuc 31i- madel A5
    By srimurthyb in forum Fanuc
    Last Post: 10-31-2012, 09:33 AM
  4. Fanuc OTT C Axis Disable - URGENT HELP PLEASE
    By BryCAM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2011, 06:15 PM
  5. Fanuc 16i-M 4th axis disable
    By MDR32 in forum Fanuc
    Last Post: 07-23-2010, 01:07 PM
