Originally Posted by
Cromaglious
I yanked my moshidraw board a week after I started using it. Took me 3 tries to find a board I liked. Arduino mega 2560 + ramps 1.4 board. I use inkscape 0.91 for generating my code using turnkeylaser extension. I upload the code using interface. And I use the turnkey recommended marlin firmware for the arduino. The MKS board is an arduino and ramps 1.4 together with some extra channels. I use an air assist nozzle with a select comfort bed air pump I modded. It's switched on by the ramps board. I do cuts of 1/4" plywood, engrave granite, so vector and raster using this setup.
Look for my post earlier this week on software, I uploaded my modded turnkey inkscape extension.
I had a engraving job running on a 85mm x 150mm granite sewing weight, it's a 8 hour job... yes the 40w is not powerful enough, but it'll get the job done eventually.
All told I have maybe $100.00 in my upgrade.
