603,939 active members*
3,248 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Importing Rhino File
    Oct 2008
    8
    Hello, How do i import a Rhino file into Mastercam X3?
    Jan 2007
    27
    In Rhino Export as a .stp file. In Mastercam open an .stp file. STEP works the best.
    Aug 2008
    64
    You can directly import Rhino files in X3, just change your file type filter to 3dm. If you are importing an assembly model I would recommend converting the Rhino file to a step file as suggested above. That way you will get each solid on a level by itself and it makes life a whole lot easier.
  1. Replies: 3
    Last Post: 03-26-2009, 11:36 AM
  2. Importing from Rhino to Mach
    By gregrnel in forum Mach Mill
    Last Post: 03-05-2009, 06:41 AM
  3. importing control point curves from rhino
    By EvanB in forum BobCad-Cam
    Last Post: 06-24-2008, 01:07 PM
  4. importing Mastercam art files in Rhino
    By sdantonio in forum Mastercam
    Last Post: 04-02-2007, 03:07 PM
