588,501 active members*
5,279 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Inserting Brackets () on 18-T Control
Results 1 to 6 of 6
    May 2007
    20
    Question Inserting Brackets () on 18-T Control
    Does anyone know how to enter round brackets ( ? ) on the 18-T series at the control?
    May 2006
    82
    Press "shift" then O for (, and "shift" N for ). I am just guessing the your Fanuc panel is the same mine.
    May 2007
    20
    Thanks . . . shift "O" or "N" . . . didn't do it. This gives an "*" with shift "N" giving a "Q" . . . as show on the keypad.
    Mar 2003
    2932
    If you don't need to use the [ ] brackets, you can change parameter 3204 bit 0 to 1, and the [ ] keys will give you (). If you do use the [ ] keys (for editing User Macros), you will need to turn on 3204 bit 2. This gives you soft keys for @,(, and ). I'm assuming you have Extended Editing?
    May 2006
    214
    Parameter 3204 Bit 0 1=() 0=[]
    If you need both leave parameter 3204 bit 0 with 0, and found you parenthesis pressing the soft right key twice, you'll see C-EXT hit that key and you'll see them.
    Jorge
    Jun 2024
    Re: Inserting Brackets () on 18-T Control
    my cnc cannot change parameters. it shows write protect. and i can't find the "parameter write []" setting in mdi to change it. the setting(handy) screen that used to appear looks missing. please help
  1. Replies: 3
    Last Post: 07-15-2011, 02:54 PM
  2. inserting custom code
    By beartrax in forum Mastercam
    Last Post: 08-29-2008, 04:53 PM
  3. Stop inserting M3
    By Big John T in forum SheetCam
    Last Post: 05-11-2008, 09:35 PM
  4. TCC v3 - keeps inserting G28 - why
    By phil burman in forum Uncategorised CAM Discussion
    Last Post: 06-26-2006, 05:29 AM
