587,511 active members*
3,336 visitors online*
    Mar 2017
    181
    INSTALLATION of an AVID 48X48
    I'm looking to buy a 48x48 AVID CNC in Charlotte, NC if I can find someone to hire to assemble it for me.
    I am disabled now and no longer have the use of my right side so I need "arms & legs".
    May be interested in buying a 48x48 used machine if someone is wanting to upgrade to a larger unit.
    Thanks,
    David
    Jan 2012
    222
    Re: INSTALLATION of an AVID 48X48
    David,
    So, point #1 (and the only point) is if you assemble it then you can fix it. If you can't assemble it yourself (disability) you still want to be there directing everything so get a teen or an adult and make a day of it.
    The reason is simple. These machines will require service on a regular basis and if you are on the phone trying to find somebody to fix it or maintain it for you then you are in trouble before you start. If you are completely disabled then I would go for a commercial machine with a local service agent. Otherwise, you are signing up for being a handyman on top of a CNC machine operator.
    With any assemble-it-yourself machine you save money the same way the homebuilders in aviation save money, by buying a kit airplane. By assembling the machine YOU have the knowledge to repair and maintain it. You have the knowledge to also bug-fix it when trouble strikes (and it will strike, trust me). The biggest cost of both aircraft and CNC machines is the maintenance. The initial investment is trivial comparatively speaking.
    BUT!!!!!!!
    Despair not!
    The instructions are simple and well illustrated. The journey is enlightening, you will learn a lot! AvidCNC is pretty darn good with their tech support. If these machines required more than a 5th grade education then very few of them would be in operation. So, there are a fair amount of people in the world that graduated the 5th grade!
    Best of luck!
  1. FS in Iowa 48x48 CNC Router
    By wmgeorge in forum For Sale Only
    Last Post: 06-03-2020, 01:02 AM
  2. AVID CNC PRO 48x48 Purchase (Mach 4 Concerns)
    By RNGPRODUCTS in forum Avid CNC
    Last Post: 01-14-2020, 09:44 PM
  3. Avid CNC 48x48 PRO (Concerned About Mach 4)
    By RNGPRODUCTS in forum DIY CNC Router Table Machines
    Last Post: 11-08-2019, 07:54 PM
  4. Looking to build Solsylva but 48x48
    By kkester1963 in forum DIY CNC Router Table Machines
    Last Post: 06-29-2012, 04:52 PM
  5. heating source for 48x48 VF-1/4 ABS
    By edwardpic in forum Vacuum forming, Thermoforming etc
    Last Post: 06-21-2007, 09:36 PM
