587,597 active members*
3,788 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > is plasma cut the good cutting method for 2mm hole?
Results 1 to 4 of 4
Hybrid View
    Mar 2008
    6
    I need to cut many holes is some hollow 316L stainless steel ball.
    The thickness is 1.5 mm.
    Today, I ask a subcontrator to do those holes for me. They use laser cutting.
    I plan to make a machine for the motion of the ball. But wonder if I can get the same quality of cut than laser?
    I need a 100% burr free cutting methode because the part is for some kind of food machinery and the inner surface need to stay clean (we fill the ball with sand before laser cutting to protect it).
    Is there any other suitable methode (other than laser and plasma)?
    You will be struggling to cut a 2mm hole with plasma
    A pierce hole is about 2.5 - 3mm in diameter
    Andy
    Jan 2008
    2247
    Holes smaller than about 3.5 to 4mm are not good applications for plasma....
    Jim Colt
    Mar 2008
    6
    Thanks for your answers.
    I will check out the EDM drilling solution.
  1. Cutting a pocket around a hole
    By pzzamakr1980 in forum Mastercam
    Last Post: 05-18-2010, 01:04 AM
  2. How small a hole can you plasma in 11 ga?
    By Stuff-Builder in forum Waterjet General Topics
    Last Post: 01-21-2008, 05:42 AM
  3. Best method to get good Cut Quality?
    By Normsthename in forum Waterjet General Topics
    Last Post: 01-18-2008, 05:35 AM
  4. Is this a good price on a plasma cam.
    By prerunner68 in forum PlasmaCam
    Last Post: 12-25-2007, 09:41 PM
  5. Best method for cutting down delrin?
    By chakup in forum Glass, Plastic and Stone
    Last Post: 10-01-2007, 12:53 AM
