587,259 active members*
3,385 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > is there a aftermarket 5-axis spindle head?
    Nov 2006
    51
    There's a possible re-work job my shop might get from one of our custumers to re-port the face and o-ring gland for a threaded hole, only problem is the parts are carbon fiber wrapped pressure cylinders, because of this the cylinders are no longer straight and when clamped the hole does not sit perpindicular to the spindle.
    We have a probe to calculate how far off and in what direction the already machined face is in but without a 5-axis machine to run the spindle along the "newly found axis" I see no way of remachining these.
    I know it's a long shot but is there such a thing as a 5 axis live spindle attachment? or a 5 axis indexible spindle attachment where the machine rather thant the operator does all the work?
    Feb 2008
    7
    Here is a web site for one....
    http://www.5-axis.com/index.html
  1. coolant pump control - aftermarket
    By MrMudd in forum Haas Mills
    Last Post: 12-06-2018, 08:09 PM
  2. X2 Spindle Head noise.
    By spaceballs_3000 in forum Benchtop Machines
    Last Post: 06-10-2008, 03:22 PM
  3. SX3 Spindle/Head temps
    By extrapilot in forum Syil Products
    Last Post: 11-11-2007, 07:32 AM
  4. J-Head Retrofitted with NMTB30 Spindle
    By jeep534 in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2007, 04:44 AM
  5. Options for 2 Axis Head (to make 5 axis)
    By drewgarth in forum DIY CNC Router Table Machines
    Last Post: 07-12-2006, 06:37 AM
