603,970 active members*
3,050 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Is there an easy way to make a Z-axis simple curve without going full 3D?
Results 1 to 15 of 15
    Mar 2006
    177
    I have an arch I'd like to cut with a straight bit, just a single swoop with the Z axis changing as the bit travels along the Y axis. I have a few instances of this. The first is in fret slots. I want to follow the fingerboard radius. The other instance is in a truss rod slot. It'd be easy to draw the curve in 2D and somehow transpose it to the Z axis. Any cheats on how to do this?
    Feb 2007
    505
    Quote Originally Posted by 777funk View Post
    not sure if I follow you correctly , cant you just rotate 90 deg. around the Y axis...then use- Mill 3 axis- engrave
    Mar 2005
    368
    I have an arch I'd like to cut with a straight bit, just a single swoop with the Z axis changing as the bit travels along the Y axis.....
    EDIT: just like Claude said ^^
    Easiest way is to draw your 2d arc in the XY plane,
    then Rotate it to the YZ plane, (you can try to draw it in the YZ plane, but the coords are very hard to follow)
    then use 3D Engrave to follow it with a toolpath.
    Play with the depth setting until you understand what's happening.
    FWIW, someone else had the same app. but wanted to be able to ruf without burying the little cutter too deep. That solution required modeling the slot to slightly larger than cutter width and using Slice Planar with a Step Down distance defined.
    Jun 2003
    446
    Yep, Claude is right on the money there. The 3D Engrave feature would be good for that.
    CNC Dude
    May 2009
    133
    3D Engrave
    3D Engrave? Is that a program? Is it free? If so... Someone have a link? Thanks!
    Jun 2003
    446
    Millwork, the 3D Engrave is a feature of the V24 software. There is a 2D Engrave and a 3D Engrave as well as V Carving with a combination V cutter and EndMill as needed. Do you have BobCAD-CAM software?
    CNC Dude
    May 2009
    133
    Oh... No I use AlphaCam. I guess I should pay a lil more attention. I didnt realize that this was a BobCad forum. Sorry! :-/
    Jun 2003
    446
    No problem. Do you make guitars?
    May 2009
    133
    No... I dont really know anything about guitars other than they make noise. I have a guy here in the shop thats in a local band that wants me to cut one for him on the CNC. If all goes well with the first one I might study up on it and make a few more for the heck of it.
    Mar 2006
    177
    I tried this and no luck. What I'm trying to do is toolpath a 3/16" spiral bit to cut a curved bottom channel for the truss rod. I drew a arched line and rotated it as mentioned and that worked just fine. But when I verify it the bit is no where near the 3D engrave toolpath. It's completely off the piece. Maybe I'm setting up the 3D engrave wrong.
    Also, how does engrave work? Shouldn't it follow the bottom of the arched line I drew with the tip of the bit?
    Here is what I'm trying to do (but CNC of course) See Photo:
    The sides of the jig are curved to create a cut that has a arched depth.
    Mar 2005
    368
    Also, how does engrave work? Shouldn't it follow the bottom of the arched line I drew with the tip of the bit?...
    First, make sure you're using the the Engrave feature under the 3-axis menu and not the 2-axis menu.
    Also, make sure your geometry is at the depth you want to machine it at.
    The Depth value will obviously adjust the Z-depth of toolpath from the geometry, but this can be set to zero and even given a neg. number to raise the path.
    Couple more things to mention, the arc will be broken into small, straight line segments.
    And the path is calculated from the tool centerline, so flat bottom tools will show a slight deviation. Certainly not an issue in your app.
    Sometimes it's easier and cleaner to just hand code a feature like this, using the CAD data for the coords. (one arc is just a single line of code).
    Mar 2006
    177
    Quote Originally Posted by moldmker View Post
    That would be awesome. Could you shed a little more light on where/how to do something like this. Sounds simple and effective.
    Mar 2005
    368
    I don't recall volunteering but here's some direction :
    First draw your arc in the XY plane,
    Profile it,
    Then modify the code, as shown.
    Note that some controls are different, ex. G3 may need to be G2, etc..
    Mar 2006
    177
    Thanks! So you are using bobcad and using your brain to get what you're after. Looks good. I may try to do it completely by hand if I can get a little more accustomed. I'd bet simple things like that would be pretty easy to program in that way. Probably easier than in Bobcad.
    Nov 2009
    4415
    Funk, It will help you infinitely to understand the code you are generating regardless of the software you use. I am just beginning to grasp some of the patterns. You need to be able to see if the tool is retracting above the part in between pockets, going to the specified depths per pass, feed rates are what you specified and so on. I seem to get a groove in almost every project I attempt from the tool not lifting. I told a friend the groove was going to be my trademark LOL. Soon I will pay more attention to my verify and read the code closer, maybe even dry run it in Mach without the machine on. I do not really understand code but it is getting better.
  1. Easy and simple cam software
    By Sharx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-30-2010, 04:38 PM
  2. Easy to make cnc router '.skp' plan
    By YIORGJX in forum DIY CNC Router Table Machines
    Last Post: 10-31-2009, 07:46 AM
  3. Bobcad v19 simple skin issue (easy?)
    By SSMrob in forum BobCad-Cam
    Last Post: 03-26-2009, 11:50 PM
  4. Simple easy CAM ?
    By jhuddleston in forum Uncategorised CAM Discussion
    Last Post: 08-26-2008, 10:26 AM
