603,832 active members*
3,882 visitors online*
    Dec 2008
    292
    Is there a way to offset the piece I want to cut?
    I have a homemade CNC router with a 8" X 9" cutting area. I need to cut pieces for a toy for my grandson, however, the gcode for the pieces expects a much larger cutting area. My machine is large enough to cut the individual pieces but can't start from 0,0 and cut far enough to get all the pieces.
    Is there a way to tell Mach 3 that I want it to start somewhere else to begin a cut. I could then bypass the code for the pieces that are beyond my machines cutting area, then go back, reset 0,0 to some other value and cut those remaining pieces from a different home value?
    Sorry if this question doesn't make sense. I just need to tell Mach3 it is at another location other than 0,0 to start. Will an 'offset' command do this?
    thanks in advance
    Don
    Mar 2003
    35494
    Change the G54 location on the offsets page.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2008
    292
    thanks, I will give that a shot.
    Don
  1. Radius Offset and Length Offset
    By jim_stoll in forum Dolphin CAD/CAM
    Last Post: 10-15-2010, 01:47 AM
  2. Please help me with this piece
    By serandre in forum Mastercam
    Last Post: 08-03-2009, 07:01 PM
  3. RFQ for (1) piece/part
    By 96Mustang460cid in forum Employment Opportunity
    Last Post: 07-11-2009, 07:33 AM
  4. My first piece, is there a better way to do it?
    By Ed from NY in forum BobCad-Cam
    Last Post: 07-03-2009, 11:16 PM
  5. Replies: 2
    Last Post: 05-25-2009, 05:22 PM
