603,336 active members*
3,951 visitors online*
Results 1 to 7 of 7
    Jul 2003
    162
    Jerky motion with CV on (solution)
    A few folks on different boards have been having problems with jerky motion on their machines (including me). The machine acts like Constant Velocity is not turned on even though the little green border is lit around the CV button.
    A poster on the Mach support board suggested I turn off CV (go to exact stop) on the general config page, and turn off the CV Feedrate button on the Settings Tab then add G64 (Turn on CV mode) in my gcode. I tried this and it worked!
    After a bit of experimenting I figured out that all I really have to do is go and turn off the CV Feedrate button on the settings tab and everything is good. Only problem is that it comes on by default whenever I start mach.
    I also noticed that choosing "save settings" from the config menu somehow turns CV Feedrate on. So if I change anything I have to remember to go turn it back off again.
    Hope this helps if anyone is experiencing the jerky motion.
    Feb 2007
    505
    cv mode
    well what is the use of the button if you have to do that?
    Mar 2003
    35494
    As long as you turn off all the CV options, it should work just fine turning it on and off with the CV button.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2007
    505
    Cool
    Still a bit confused about the cv feedrate in the setting tab window , when should someone use it ? after setting my motor at a different feedrate with motor tunning,and,( with C.V. on), I had to match the feedrate in the setting tab for them to work properly...
    Mar 2003
    35494
    Quote Originally Posted by Claude Boudreau View Post
    When you know exactly what it does and how it works, and you know that you need it.
    The general rule for the majority of users when using CV mode is to turn ALL the CV settings off.
    Gerry
    Feb 2007
    505
    Cool all the cv option
    can you name all the cv setting in mach3?
    Mar 2003
    35494
    I think there are 4 in the General Config, and the 2 on the settings page. Looks like 1 is duplicated.
    General Config:
    Plasma Mode
    Distance Tolerance
    G100 Adaptive Nurbs
    Stop CV on Angles >
    Then, on the settings page, you have:
    CV Distance
    CV Feedrate
    The CV doc on the Mach website has more info.
    http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf
    Gerry
  1. Jerky Movement
    By elogicca in forum Mach Mill
    Last Post: 11-22-2007, 03:19 AM
  2. Jerky Movement on Interact 1 MK2
    By palikalsi in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2007, 11:41 PM
  3. Jerky Z axis????
    By bill south in forum Benchtop Machines
    Last Post: 09-10-2006, 03:33 PM
  4. Bridges & jerky movements.
    By Moondog in forum Machines running Mach Software
    Last Post: 07-30-2006, 04:28 AM
  5. jerky toolpath from rhino model
    By senor J. in forum Rhino 3D
    Last Post: 02-08-2005, 12:36 AM
