Hello, This is my first post on this forum. I have been reading it for about a month and have finally got my CNC set up. I am using Mach3 with a Chinese control box. I have been using NCPlot to generate my gcode files from DXF files which has been working pretty well.
I am now stuck on an issue that I cannot seem to figure out so I have decided to post on the forum so a kind sole can help me move forward. I have a laser cutter at work and use it all the time. I generate a PDF file with a red line where I want the laser to cut. When I moved into CNC I could not/can not wrap my head around how you would design files and keep the right dimensions.
My issue is I want to create complex shape that is about 1 inch by 2 inches. I create a DXF file for it and then import it into NCPlot and make gcode. Whenever I print this file with MACH3 the drill goes along the centre of the line and does not take into consideration the size of the drill so if I had a 10cmx2cm square it is actually a 1.5 mm off because the drill is 3mm in diameter. Where can I set the size of the drill and then specify if I want the drill to move alone the outside or inside of the line?
Another issue I am facing is that if I want to cut a shape with something inside of it, gcode always goes around the outside of the shape first, then tries to do the inside which never works because the piece of wood is free to spin.
I probably sound like a huge noob. I thought I would figure it out since I already use a laser cutter but boy CNC is a whole new ball game.
