603,352 active members*
3,717 visitors online*
Results 1 to 7 of 7
    Mar 2004
    1527
    LASER scanning
    I bought a LASER displacement sensor off eBay with the idea of scanning parts. This sensor outputs the very common 4-20 milliamp. A galil board needs 0-10 volts. I started with a very simple resistor for the conversion but found a ripple in the voltage reduced accuracy. So a EE friend designed the attached 4-20 milliamp to 0-10 volt converter. Also attached is a graph of this Omron sensor performance.
    Next I wrote code for my mill's .cbk file. See the attached text file. This code uses G101 to record LASER displacement sensor values to a file. The format of this Gcode is G101 X_ Y_ I_ F_ X,Y,F work just like G1 in any Gcode. I is the increment between laser readings. To scan a part, write a Gcode file to run the laser over as many passes as needed. Parametric programming (looping and incrementing X or Y) can keep this program fairly small.
    So far, I've scanned as fast as 4ipm with readings every 0.002" with good results.
    Enjoy
    Karl
    Attached Files Attached Files
    Jan 2007
    219
    Very Interesting. Do you have a link to the sensor that you used? Was it expensive?
    As for the 0-10V output, what is the purpose of this? Dose it have something to do with height.
    Also, What kind of machine are you running this on.
    -Adam
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
    Mar 2004
    1527
    Quote Originally Posted by Adamj12b View Post
    -Adam
    http://www.omron247.com/marcom/pdfcatal.nsf/PDFLookupByUniqueID/46021884A762C2E086256A31006B2E69/$File/D02Z4MWR0401.pdf?OpenElement
    Promise not to call the sheriff? I stole it - $80.
    Laser displacment sensors like this one put out an analog value proportional to the distance or Z height in this setup
    Camsoft control on an Excello knee mill
    Apr 2005
    38
    Results?
    Hello,
    Any chance you could post some results, (pics)???
    Thanks Dave
    Mar 2004
    1527
    Laser scan arcs
    Here's a macro to laser displacement scan arcs.
    My concept: Scanning a grid of readings to a file just gives a point cloud that is complex, at best, to turn into a CNC program to replicate a scanned surface.
    I have found that with a little study a CNC program can written for the X and Y coordinates on how a replicated part surface should be machined.
    1) I write this program and test.
    2) Then change all G01 to G101, all G02 to G102, all G03 to G103. Run the Laser displacement sensor programs to get the Z depths.
    3) Rewrite the program in 1) with Z depths. Machine part.
    This goes really fast, no complex design time. I've done a couple parts, only downside is careful inspection for error readings is needed. Edges are giving the most trouble.
    Karl
    Jan 2007
    206
    So you are using your mill as a CMM to reverse engineer your part?
    Does it record the measurments into your CNC control or into a seperate CAM package? are you using the Cam Soft 3000 or something different. I saw the laser on there web site and was thinking about building a measurment machine. but mounting the laser to the mill takes care of a lot of issues.
    Thank You
    Farmers Machine
    Mar 2004
    1527
    Quote Originally Posted by Farmers Machine View Post
    Thank You
    Farmers Machine
    Yes, poor man's CMM. Exceptional accuracy if you pay attention to detail.
    The data is recorded to a text file as a series of X Y Z coordinates.
    You quickly end up with a HUGE number of points, or point cloud. A package called Rhino can handle the data and turn it into a model that is in turn imported to a CAM package. This is NOT my area.
    I found a shortcut for the parts I needed to copy. Carefully plan your X and Y moves to machine the part; write this Gcode file. (Note that my G101 is linear laser read, G102 is CW laser read, G103 is CCW laser read). Spend some time thinking exactly where you need Z readings. Now modify the Gcode (add 100, put in read increments) to read your Z values off the part and run laser program. Input your Z values into the original program(I automated this step) and you are ready to machine.
    Karl
  1. 3D Laser Scanning Services Offered
    By GJMATHEWS in forum News Announcements
    Last Post: 06-14-2010, 10:04 PM
  2. What is best for scanning? Led or tube laser?
    By jaru-eri in forum Digitizing and Laser Digitizing
    Last Post: 06-08-2008, 10:01 PM
  3. scanning on the tormach
    By RB1 in forum Tormach Personal CNC Mill
    Last Post: 01-10-2008, 07:18 PM
  4. Need Laser Scanning Advice
    By Rico55 in forum Digitizing and Laser Digitizing
    Last Post: 09-20-2007, 02:33 PM
  5. Is this the way 3d scanning will go ?
    By greybeard in forum Digitizing and Laser Digitizing
    Last Post: 02-15-2007, 06:52 PM
